Sedan owners with Top Speed Pro 1 Y-back
Old Feb 7, 2020 | 01:26 PM
afrayedknot's Avatar
afrayedknot
The TS mid-pipe has a metal plaque engraved TopSpeed and I believe the orientation can have an impact on the fitment, such as rubbing on the rear sub frame that some owners have mentioned.
When I had my exhaust installed at the shop, we intuitively installed it with the plaque facing down, based on fitment and that the plaque would be hidden if facing up... I haven't had any issues with the rear sub frame rubbing, but I have to admit that my exhaust tips are pretty close (5mm) to the bumper. I spoke with a TS rep about this, but they weren't exactly sure. They believe the plaque should be facing up towards the car.
My question is for those that have this exhaust. Which orientation do you have your mid-pipe installed? And did you experience any issues with the rear sub frame or exhaust tips being extremely close to the bumper cutouts? I have a feeling installing the mid-pipe with the plaque facing up may result in the rear sub frame rubbing, as it angles the exhaust up towards the body of the car. I've found many posts where both orientations are used, so it's definitely not one way or the other.
Old Feb 7, 2020 | 10:48 PM
latino914's Avatar
latino914
Wow are they still messing up on batches of this. I had to flip mine so it wouldn't hit the rear subframe.
Old Feb 9, 2020 | 03:27 AM
afrayedknot
When it was hitting the rear subframe, what orientation was the mid pipe? Does yours have the TopSpeed plaque? If so, which way was it facing when you had the subframe issue?
It's possible that the plaque was attached on the opposite side of the mid pipe for different manufacturing batches, so a better descriptor of the mid pipe orientation would be which angle does the mid pipe branch bend? Up or down?
The attached photos show the TS mid pipe plaque facing down and the pipe angled upwards towards the undercarriage of the car. On my mid pipe, it is the opposite. The pipe angles downwards when the plaque is facing down. I don't have issues with the rear subframe, but this did force the tips a lot closer to the bumper. When I get a chance I'm going to swap it and see if the tips fit better.
Old Feb 9, 2020 | 05:52 PM
steveng37's Avatar
steveng37
Could you post a clearance of yours of the brace down by the mufflers? That's where mine had a fitment issue. Curious to see how yours fits under the brace/bracket. I didnt have any issues with the midpipe, had it installed yesterday, although I'm not sure what way the plaque was facing
Old Feb 9, 2020 | 06:06 PM
afrayedknot
I'll try and get a photo tomorrow. You want to see the clearance of the sub frame? I no longer have my center bracket installed, because the mid pipe angles into it.
Old Feb 13, 2020 | 10:05 PM
latino914's Avatar
latino914
I had to remove my center bracket since it would hit the midpipe. But it was better since it then wouldnt hit the rear subframe.
packotictacs
Dec 12, 2017 01:51 PM
Moe_G37x
MODDING 411
May 17, 2016 10:10 AM
SnowbunnyG37S
Intake and Exhaust
Jul 19, 2014 02:11 PM
Himalaya
Jul 12, 2013 02:39 PM
FromZeroToKing
Jun 4, 2013 03:04 PM
