2012 G37 Sedan - Missing Mirror Cap
Old Apr 14, 2019 | 05:02 PM
summerwind's Avatar
summerwind
Question 2012 G37 Sedan - Missing Mirror Cap
Will be a year in June since I was last here. Just love this 2012 but living in a metro area seems not good for it.. Why would someone pry off the back cover of side view mirror driver's side? Now wires are all exposed and it's snowing. What to do? Can I order replacement part just the back housing and pop it back in? Appreciate your help.
Old Apr 14, 2019 | 10:52 PM
13_SkylineSedan's Avatar
13_SkylineSedan
Try here:
https://www.infinitipartsusa.com/201...are-s/1825.htm
Click on "Front Door > Outside Mirrors" and choose the one for your car (sedan or coupe, then left or right). I believe the cover is held in place by "pawls" so you should be able to snap on a replacement. However these are probably unpainted.
Once you find the part number from that site, you could also search ebay. There you may find a used one - or a complete mirror - in your paint color...
Old Apr 15, 2019 | 10:00 AM
summerwind's Avatar
summerwind
Thank you for your response. Is the replacement part universal i.e. good for all G37 (journey, sport, etc) because when I filtered down to G37-X, the parts list does not show. Also, when I selected the part #, G37 Journey is highlighted. Would that part work for the G37-X?
Old Apr 15, 2019 | 01:28 PM
13_SkylineSedan
Looks like it's the same part number for the X. At the top of that page you see the path:
"Home > Factory OEM Infiniti Parts > 2012 > G37 > G37 - Journey > Body Hardware"
Click on "G37" to go backwards and chose your model, then "Body Hardware", then "Front Door > Outside Mirror (Sedan or Coupe)" then "Left (or Right) Mirror Cover"
Old Apr 15, 2019 | 09:42 PM
summerwind's Avatar
summerwind
I did as you say and it is the same part numbers. Cover clips right back in to install? Thanks so much for your help!
PMTW_IPL
Jun 10, 2019 06:10 AM
MichaelYYZ
Apr 14, 2019 07:05 PM
JesseG37S
Apr 12, 2019 10:37 PM
TooKool
Apr 1, 2019 12:57 PM
ARogers502
Mar 22, 2019 03:36 PM
