Gas not wanting to pump
Old Mar 11, 2019 | 08:52 PM
Conboss's Avatar
Conboss
Actually had this issue earlier... pumped 40 litres, stopped itself. I managed 55 or so litres before I gave up
Old Mar 18, 2019 | 03:50 PM
Conboss's Avatar
Conboss
Originally Posted by inf4mOus
Replace the EVAP canister with the EVAP Purge. This is 100% the fix. I had this myself which annoyed the **** out of me for the longest time. Eventually I said f*** and got to the bottom of it.
had mine replaced April of last year when I bought the car. I’m going to get gas tonight, we’ll see how it goes
Old Mar 18, 2019 | 04:23 PM
saywat?'s Avatar
saywat?
i replaced mine too. thats the real fix. i had a code so i knew what to replace. u got a coupe or sedan? i got a coupe and couldnt get the sensor off i had to break the clip and modify the clip on the new sensor.
u replaced the sensor last year and only putting in gas now?
Old Mar 18, 2019 | 04:27 PM
Conboss's Avatar
Conboss
You nuts? I fill up every week! I just haven’t had many issues with the Evap system yet
Old Mar 18, 2019 | 09:48 PM
saywat?'s Avatar
saywat?
oh correction nm what i replaced was the vent control valve only. i bought it new oem bout $100
Old Mar 18, 2019 | 09:53 PM
Conboss's Avatar
Conboss
Filled up today and the gas stopped pumping at 50ish litres. Made it drink to 52 and the needle still doesn’t hit the top mark!
Old Mar 18, 2019 | 10:03 PM
saywat?'s Avatar
saywat?
^ u replaced with brand new canister and/or valve? oem?
Old Mar 21, 2019 | 12:14 AM
BrianG314's Avatar
BrianG314
As a few others have mentioned just pull the nozzle out halfway, that's always solved it for me.
Old Mar 21, 2019 | 02:38 AM
antirice's Avatar
antirice
I ran into this problem in the past. I put the pump trigger in "slow fill" setting that seems to do the trick.
landslide03
Jul 18, 2015 10:13 PM
solopresident
49
Oct 11, 2013 01:16 PM
