For sure the passenger side cat heat shield is dented. Maybe the cat casing itself isn't? OP, it would be quite costly to find someone who would weld up that cast aluminum piece. You're better of replacing it with one scavenged from a junkyard.
o ok appreciate all you guys input anyone know how much it going cost to replace the subframe
I agree on the cat. If it's not throwing a code then he's prob fine and it's just the heat shield.
OP, do you not have insurance on the car? Depending on your deductible you may be better off just going through insurance.
What kind of block did you run over?? A brick maybe? I hope you're not driving the car until this gets repaired!
o no I can't drive it my airbag in my steering wheel came out and my insurance company acted like they were going fix it then two days later said they won't going fix it I hate insurance companies
