Grounding Kit 2010 G37 Sedan?
Old Feb 12, 2018 | 10:43 AM
bloodbruise's Avatar
bloodbruise
I actually had too much cable and had to maneuver it so it wouldn't touch the serpentine belt, or not look atrocious. So yeah it fits fine. I started with the shortest cable and ended with my longest just to be safe, and it worked out fine. 29.7mpg going to work today, but it is a 27 mile mostly freeway commute.
Old Feb 12, 2018 | 11:03 AM
iCrap's Avatar
iCrap
Ah ok. I'll give it a try then. Worst case i cut and re-crimp
Old Feb 12, 2018 | 12:09 PM
Baadnewsburr's Avatar
Baadnewsburr
Originally Posted by ryanwhite74115
Link where to purchase?
Originally Posted by iCrap
You make it. there was a member who was making kits but I don't think they do anymore.
Stillen makes a kit you can buy https://www.stillen.com/stillen-grou...es-606358.html
Old Feb 12, 2018 | 12:18 PM
bloodbruise
From what I understand the stillen grounding kit is 8gauge and what I bought was 4 gauge. I prefer the thicker wire. Really what your paying for is the stillen name
Old Feb 12, 2018 | 12:54 PM
iCrap's Avatar
iCrap
lol $100 for some wires. Realistically, a spool of wire and some crimp on connectors is only like $10-15.
Old Feb 12, 2018 | 12:57 PM
bloodbruise
That's why I was fine paying $20 for mine on Amazon. :P
Old Feb 12, 2018 | 04:15 PM
tigerlui's Avatar
tigerlui
I have some extra cables left over from my DIY. I might be able to put together a few kits and sell them to anyone that is interested. They are 4 gauges.
I did the following change to that DIY kit.
No battery to chassis cable, another search on the forum found that the battery - chassis ground will cause the voltage module malfunction and shorten the battery and alternator lifespan. See post #5 in this link:
https://www.myg37.com/forums/g37-cou...ml#post2917296
Add 4 gauge power cable from alternator to battery positive
add 8 gauge throttle body grounding cables for both sides.
Old Feb 12, 2018 | 04:16 PM
ryanwhite74115's Avatar
ryanwhite74115
I would pay
Old Feb 12, 2018 | 04:26 PM
duriisimo's Avatar
duriisimo
. Me too
Old Feb 12, 2018 | 05:54 PM
PNW_IPL's Avatar
PNW_IPL
Me too
I'm in for this too
Old Feb 12, 2018 | 06:01 PM
Baadnewsburr
I'm trying to visualise this, can you post pictures of your wiring routing/hook up points?...also just so I'm clear all your grounding wires are 4 gauge except for the the throttle body grounding cables?
Old Feb 12, 2018 | 06:52 PM
tigerlui's Avatar
tigerlui
Thanks for the support. I don't have time to put this together until 2 weeks later. I will create a separate post for this.
Hashim, yes, all 4 gauges except throttle body grounding.
Old Feb 12, 2018 | 06:57 PM
slartibartfast's Avatar
slartibartfast
Me four.
Old Feb 13, 2018 | 07:16 PM
  #29
saywat?'s Avatar
saywat?
Originally Posted by bloodbruise
It idles at like 500 rpm now, and shifting in DS mode is so much cleaner. My gawd
normal idle is 650 +- 50 brah
Old Feb 14, 2018 | 01:47 PM
  #30
kroy's Avatar
kroy
Let me know if you end up putting together a kit, I might be interested too. Thanks.
