Help!! Car Won't Start :-(
Old Jan 24, 2018 | 01:38 PM
peterso2's Avatar
peterso2
Hello All. I have a 2010 G37 with the original battery (probably about 8 years old?) With this extreme cold weather its been garage kept lately and needless to say the battery wouldnt start. So I replaced it with a interstate (changing the battery is kinda a pain in these cars). It started once after I installed it but I didn't let it run long.
Now When I go to start..it tries to crank but makes more of a grinding sound. Is there a possibility the battery didn't come fully charged? It sounds like more of a electrical sound than an actual engine trying to crank over. I'm concerned and confused. I'll go home and check polarity of the battery but I believe it is correct. Thoughts on what it could be? Should I try to add jumper cables to charge it up more?
Thanks! Jason
Old Jan 24, 2018 | 01:59 PM
presidentsdad's Avatar
presidentsdad
The one time it did start, did it sound sluggish when the starter was running?
Old Jan 25, 2018 | 09:43 AM
Michael_in_DE's Avatar
Michael_in_DE
do you have a multimeter? check the battery voltage. And assuming its connected right, it wouldn't hurt to jump it.
Old Jan 26, 2018 | 07:30 PM
peterso2's Avatar
peterso2
Folks. Ive determined battery is fine, its getting the juice to crank but theres no fuel coming. I'm narrowing it down to a fuel supply problem. Any idea how to investigate further? I'm hoping I can solve this without a tow to a dealer :-(
Old Jan 26, 2018 | 08:41 PM
slartibartfast's Avatar
slartibartfast
I'd check the fuel pump fuse first.
Old Jan 26, 2018 | 11:15 PM
dkmura's Avatar
dkmura
20 Year Member
Get a code reader and pull codes before you do anything else.
Old Jan 27, 2018 | 11:02 AM
presidentsdad
FYI...the fuel pump is underneath the rear seat. Very easy to get to.
Old Jan 27, 2018 | 01:14 PM
peterso2's Avatar
peterso2
Folks - thanks for your help! I checked all fuses and last night I pushed the pedal a little bit as it was cranking and I was able to get it started. Blew out a lot of smoke upon startup but after I drove around for a bit seemed to run fine. I think sitting in the -30C cold blast we had for 2-3 weeks caused some fuel supply issues. Anyways...thanks for your help guys! She's back on the road now!
Old Jan 27, 2018 | 11:50 PM
presidentsdad
Yay! That's always a good feeling!
Old Jan 29, 2018 | 02:07 PM
Michael_in_DE
Might have gotten some water in the gas, that then froze in the lines overnight. Happens all the time in north. Happened to me once. Be careful where you get your gas from.
MYG376MT
12
Feb 1, 2013 01:59 PM
RhiNoKiLL
Jun 21, 2011 12:53 AM
Redvoodoo
Jun 8, 2011 12:37 PM
hopgo
Dec 15, 2007 06:44 PM
