Exhaust Diameter?
Old Jan 17, 2018 | 06:35 PM
zaz's Avatar
zaz
Exhaust Diameter?
I've looked around the forum and there are many different numbers thrown around, with the most common being 2.25". I wanted to know the diameter right at the axleback. I was looking to have my mufflers cut out and swapped with the 14851 magnaflow which has an inlet of 2.25". Any recommendations? Anyone done something like this before? Would this work just fine or is the diameter not accurate? G37xs sedan btw. Thanks ahead of time!
Old Jan 17, 2018 | 06:53 PM
slartibartfast's Avatar
slartibartfast
https://www.myg37.com/forums/intake-and-exhaust-328/
Search here.
Old Jan 17, 2018 | 07:02 PM
zaz's Avatar
zaz
I had the same issue there. I've seen numbers as low as 1.9" and as high as 2.25". No luck finding anyone who ran these mufflers either, just some that ran a flowmaster super 44.
Old Jan 17, 2018 | 08:06 PM
slartibartfast
You're looking for stock pipe diameter, right? It's in the forum I linked.
Old Jan 17, 2018 | 08:09 PM
zaz's Avatar
zaz
There was mention of stock pipe right before mufflers on sedan being 2.25" on some posts, and some stating 1.9" or 1.75", someone even said 1.5" (?????). It's so all over the place. Hence why I asked, because there wasn't a conclusive answer.
Old Jan 17, 2018 | 08:10 PM
slartibartfast
On my sedan, pipe is 1.9 inches.
Old Jan 17, 2018 | 08:13 PM
zaz's Avatar
zaz
So I shouldn't order the 14851? I was looking at those specifically because of 2.25" diameter, and a lot of people have bolted it onto other cars (Audi A4, S4, Nissan Maxima, Honda Accord, etc.) hence why I asked.
Old Jan 17, 2018 | 08:19 PM
slartibartfast
This is your opportunity to buy larger pipes.
Old Jan 17, 2018 | 08:41 PM
zaz's Avatar
zaz
I didn't want to do axleback because in Canada the price is unreasonable (well over $1k). I could get these welded on for ~500 hence why I was considering it, but only if it works of course.
Old Jan 18, 2018 | 09:38 AM
NealP's Avatar
NealP
I believe stock sedans are 2.25" whereas the coupe is 2.5". You can measure for yourself though ;-)
Old Jan 18, 2018 | 10:18 AM
RMB5190's Avatar
RMB5190
The size varies from Y- pipe to Mid pipe, etc. For the most part, excluding flanges, inlets, outlets, etc, the pipe is around 1.8-1.9. Regardless, it's a toothpick and the stock mufflers are very restrictive. The mufflers you're interested in will weld right in.
jsampsell
Nov 2, 2014 10:54 PM
Ibanez540r
Intake and Exhaust
21
Jul 3, 2014 05:22 PM
Abdiel
Intake and Exhaust
Sep 5, 2010 11:09 PM
donaldp
Nov 7, 2008 04:59 PM
bboysteele
Intake and Exhaust
22
Aug 5, 2008 12:42 PM
