New Catalytic Converter for P0420 Code
Old Sep 29, 2017 | 11:22 AM
jkim972's Avatar
jkim972
I got a P0420 code for catalytic inefficiency on my 09 G37x. I read the code and this is for bank 1. which is passenger side based on my search. What are some of your recommendation on replacing this part? I don't want to spend close to $1k dollars to do one side with OEM part since my car already has over 100k miles on it. Is there more economical solution to this problem?
Old Sep 29, 2017 | 11:49 AM
Vizard_87's Avatar
Vizard_87
time for some high flow cats
Old Sep 29, 2017 | 12:34 PM
jkim972's Avatar
jkim972
I thought about that. But then, does that mean I will have to replace both sides?
Old Sep 29, 2017 | 12:54 PM
Vizard_87's Avatar
Vizard_87
yup, but i think even a pair is less expensive than oem catalytic converter, i think
Old Sep 29, 2017 | 07:14 PM
the_wolff's Avatar
the_wolff
Where are you located? OEM cats come up in the forum classifieds from time to time.
Old Sep 29, 2017 | 08:54 PM
qmantran's Avatar
qmantran
$1,000 for 1 oem cat
or
$500 for 2 high flow cats and you gain power. Hard decision.
Old Sep 30, 2017 | 01:04 AM
Melophile's Avatar
Melophile
Brand new pair of high flow cats: ~$500
Brand new OEM cat (only one): ~$500
Used OEM cat: $50-100
Old Sep 30, 2017 | 02:31 AM
jkim972's Avatar
jkim972
I’m in Texas. I’ll check it out
Old Sep 30, 2017 | 01:26 PM
Ricio1991's Avatar
Ricio1991
If you really want oem cat used look online there’s always plenty of ppl selling them
Old Sep 30, 2017 | 05:33 PM
Gus_Mahn's Avatar
Gus_Mahn
Some cars still get a P0420 with hi flow cats. Are Infiniti's one of them?
Old Sep 30, 2017 | 07:22 PM
Vizard_87's Avatar
Vizard_87
depends which ones you get. never got any with fast intentions rhfc
Old Sep 30, 2017 | 07:45 PM
the_wolff's Avatar
the_wolff
No issue with Berks HFC here.
Old Oct 1, 2017 | 01:10 AM
qmantran's Avatar
qmantran
Had a 2008 Acura TL with deleted cats for straight pipes. Never had a check engine light. Thanks to defoulers.
Got fast-intentions high flow cats with defoulers on my G37 and never had a P0420. However I got a P2A03 code because my driver side high flow cat developed a crack.
I did buy my high flow cats used from another member and installed them Dec 2015 and put about 40,000 miles on them.
