Buying a 2011 G37s sedan, What to lookout for
Old Jul 19, 2017 | 03:12 PM
  #31
sonors's Avatar
sonors
Originally Posted by NW_6MT
Apologies if this is too late, but as a recent buyer of one of these cars. I would recommend that you check all the common water intrusion points for molestation (sun-roof drains, wiring harness grommet near the battery, lower windshield trim). If it looks like parts have been removed multiple times or are messed with and not aligned it could be a red flag. My car didn't have any of these signs and short of asking the owner if he'd leave it in the rain for a week and intermittently drive it a few times then sit it then drive it and then park on a hill and then park it flat and then.... you get the idea. I don't know how I would've known...
Sorry, rant over. This to me is the weirdest problem with these cars...
Dang! I just took it for a PPI and got a clean bill of health. I had noticed a pretty strong odor but thought the previous owner may have had a dog in the car since there were some scratches on the dash and the aluminum door trim. Odor could be due to water leak problems? Before returning to the dealer I took it home and poured water into the sunroof channels and all 4 drains seemed to work. Wish I knew about this issue then as I would have checked the carpet as well. How hard is it to resolve this if it is a leak? I bought a used Caddy a few years back that wound up having a bad trunk leak. Took me a couple of months to finally fix it.
Old Jul 19, 2017 | 03:38 PM
  #32
Victory's Avatar
Victory
The water infiltration only happens when the drains get clogged. If you park outdoors, clean the drains once a year when you condition your doors seals and lubricate the hinges and tracks.
Smart move getting the PPI. You're probably in good shape
Old Jul 19, 2017 | 03:44 PM
  #33
slartibartfast's Avatar
slartibartfast
Clean once per week??? Mine get cleaned once a year whether they need it or not. It's over a grand if the tubes dry out at the firewall and you let Infiniti fix it.
Old Jul 19, 2017 | 03:45 PM
  #34
RMB5190's Avatar
RMB5190
He said once a year my man
Old Jul 19, 2017 | 03:48 PM
  #35
sonors's Avatar
sonors
Research says otherwise. It seems that it is entirely possible to have cabin leaks even if drains are flowing. I was not aware of this until a couple of hours ago. Now I think it might be the reason for the dank smell in the car I'm looking at.
Old Jul 19, 2017 | 03:51 PM
  #36
slartibartfast
Holy schmoly!
Old Jul 19, 2017 | 04:10 PM
  #37
Victory's Avatar
Victory
Well, yes, if the drains are flowing into the cabin due to broken hardware instead of out through the firewall. Should be easy enough to check. Just pull the carpet back by the firewall and look for signs of moisture.
The musty smell is most likely because the previous owner never shampooed the carpets or changed the air filter.
Old Jul 19, 2017 | 04:17 PM
  #38
sonors's Avatar
sonors
If I had possession of the car I'd do that. Was not aware of this issue until after I returned it to the dealer following a PPI. I did check the sunroof drains and they appeared to all be flowing since I saw puddles near all 4 tires. I'm hoping the cause of the smell is what you describe.
Old Jul 19, 2017 | 04:19 PM
  #39
Victory's Avatar
Victory
Yes, unless you got water in the cabin testing those drains, you're fine. Change the cabin air filter and get the interior detailed or make it a condition of sale.
Old Jul 19, 2017 | 04:53 PM
  #40
NW_6MT's Avatar
NW_6MT
Not remotely true. There's a little gasket on the connector that links the drain tube to the firewall. It degrades and leaks there. Clogs/dirt/etc have nothing to do with it. Do some searching on this site for dashboard leaks and you'll see pics of the worse design in the history of automotive engineering (I may be biased, but it does suck).
Old Jul 19, 2017 | 05:00 PM
  #41
sonors's Avatar
sonors
It was your plight that brought this problem to my attention. Did you ever get it totally resolved? I'm pretty sure this is why the car I am considering smells so bad. Can not think of any other reason. If it is fixable I won't let it kill the deal.
Old Jul 19, 2017 | 09:20 PM
  #42
ezbme's Avatar
ezbme
2011 is the best. 2012 and 2013s are okay I guess.
Old Jul 20, 2017 | 04:39 AM
  #43
NW_6MT's Avatar
NW_6MT
I'm fairly sure the passenger side is fixed. It's hard to be certain as it is so intermittent, but I haven't had any more trouble. I had a little dripping one time on the driver side but it was barely any water and it never recurred so I haven't torn into that side. I'm dreading it but next time there's a drip I'm all in.
If there is any moisture down along the floor it is worthwhile to pull the carpet and have a look. It's pretty easy to do and there is basically a reservoir in the floor along the door with the way the floorpan is shaped. My passenger side easily had a gallon of water sitting there when I first noticed the leak.
Old Jul 20, 2017 | 07:47 AM
  #44
sonors's Avatar
sonors
I think I'm going to pass on this particular car after all. I am pretty certain it leaks. And judging by the smell it must have been leaking for a while. No telling what is under the carpet. Just wish I'd known about this issue before I dropped $120 on a PPI.
Old Jul 24, 2017 | 03:58 PM
  #45
JZ310's Avatar
JZ310
ended up picking it up last night. on the hunt for the lip now!
