Need help - what is this part
Old Apr 15, 2017 | 01:27 PM
dhknchong's Avatar
dhknchong
Need help - what is this part?
Hi guys. I need some help identifying a part. I was changing the spark plugs on my 2009 G37 sedan. I was having a hard time getting the right side air duct off. As I was wiggling it around this part popped off. What is the name of this part. Do I need to replace it or does it just pop back on. Thanks in advance for any help you can give me.
Attached Thumbnails Need help - what is this part-img_7700.jpg   Need help - what is this part-img_3231.jpg   Need help - what is this part-img_8773.jpg
Old Apr 23, 2017 | 02:20 AM
crookncastle's Avatar
crookncastle
thats the nipple for the pcv breather hose. it looks like comes attached with the entire valve cover meaning its not sold separately. if i were you u can clean off the surface of the valve cover and the nipple real good and then use jb weld to fuse it back together. don't run the car for a day and let it dry and seal before attaching the breather hose back on.
Old Apr 23, 2017 | 08:34 PM
dhknchong's Avatar
dhknchong
Thanks for the response. That's exactly what I did. I cleaned it off real well and used JB weld to put it back together. It worked perfectly.
