White & Silver sedan owners- what do you do to eliminate rail dust?
I have a 2013 G37S sedan in white. Silver is the other color that is bad for showing rail dust. I put Auto Armor wax on the body panels thinking it might help, but that does not seem to do much.
I washed my car yesterday and had to use the clay bar again as the rail dust (orange spots) was all over the car. What do you guys with white and silver cars do to eliminate rail dust? I was thinking of switching to ceramic brake pads for the street, but not sure if that would help.
Let me know your experiences and ideas. Thanks!
Claybar works just fine. I clay twice a year, sometimes more, as needed for problem sections... lower doors, rear bumper and trunk face.
I don't use Iron-X, because I don't put enough miles on the car for rail dust build up to be a continual problem. Mostly, it's a springtime consideration, after the paint has been neglected four months or more.
But I relate to your discontent. Moonlight White makes those little orange specs really stand out. On the upside, it's helpful to actually see them when claying the car.
If your rail dust problem is severe... check out Iron-X. And if you do, bump is thread with details.
I stopped using a traditional claybar a few years ago when I was introduced to the Nanoskin Wash Mitt:
That should do the trick and can be done while washing the car with the same soap.
I stopped using a traditional claybar a few years ago when I was introduced to the Nanoskin Wash Mitt: https://www.amazon.com/Nanoskin-AS-0.../dp/B00DOS0LH2
Another thought I had was switching the stock brake pads over to ceramics. I think this is what I did on my white Evo, but I cannot remember if that helped with the rail dust or not. Anyone else try different pads with any success?
Iron-x and the Nanoskin wash mitt seem interesting to me if they are easier than a clay bar. I am just sick of using a clay bar and rubbing the car until my arms go numb. Can either of these products be picked up at a regular auto parts store like O'Reilly, Autozone, Advance, Napa, etc, or do you have to order them?
I got my wash mitt from Amazon and it's pretty nice. I've seen it over at advance too.
Anyone else notice less rail dust with ceramic pads vs. stock pads?
You might cut down on the amount of rail dust by changing brake pads, but it won't eliminate the issue. Semi trucks can produce quite a bit of rail dust when braking and there's not much you can do if your car gets caught in the slipstream and they imbed into your paint. I took delivery of a new car that came on the back of a truck and I was shocked how much rail dust there was on it. Your car can pick up a little from other vehicles as well, albeit marginal.
I've had decent results in cleaning with iron x, but it doesn't get every last spec off. After using iron x I'll usually pull the car in the garage and spot clay any spots that it may have missed. Wax is not strong enough to prevent rail dust. You can try ceramic coating and see if that will help cut down on rail dust as well. That would be my suggestion, short of applying PPF on the entire car.
PPF? Paint protectant film- like the wrap they put on the cars at the factory?
Anyone else have good luck with ceramic pads?
