Sedan weight reduction
Old 02-08-2020, 10:45 AM
  #196
4DRZ
4DRZ's Avatar
Originally Posted by PNW_IPL
Car weighs nothing now haha.
That's one way to drop weight and just think of all the added headroom. However, the seats don't look too comfortable.
Old 02-08-2020, 10:48 AM
  #197
PNW_IPL
PNW_IPL's Avatar
Haha!
While the carpet was drying I test fit the bride rail. Now im Excited to get a seat. After reading Amazon reviews on the r600 I'm probably too fat. 5'8 195 with a belly waist 35 ish. So back to drawing board
Old 02-08-2020, 10:53 AM
  #198
4DRZ
4DRZ's Avatar
Haha!
The Sparco R600 is a great seat, but the butt/thigh area is where it is initially pretty tight- it does break in a bit over time. It is actually not too tight through the waist. However, I would strongly recommend trying to sit in one first just to be sure.
PNW_IPL (02-08-2020)
Old 02-09-2020, 12:19 AM
  #199
PNW_IPL
PNW_IPL's Avatar
While the carpet is out, figured I'd shed a few pounds.
The following 2 users liked this post by PNW_IPL:
Joyryde (02-09-2020), SupraOfDoom (02-09-2020)
Old 02-09-2020, 12:47 AM
  #200
Joyryde
Joyryde's Avatar
Holy sh*t! Someone is actually doing it! I removed mine from the trunk area, use a heat gun, chisel and goof off. When you take her out for a spin could you tell us if the cabin noise is louder or not?
Old 02-09-2020, 03:39 AM
  #201
SupraOfDoom
SupraOfDoom's Avatar
Seconded.
Old 02-09-2020, 10:10 AM
  #202
slartibartfast
slartibartfast's Avatar
In re seats: bucket width is probably most important. Go to ultrashield.com and download their measuring pdf to learn how wide you need. All the good seat makers specify bucket widths and such.
As for noise, you might consider epoxying a longitudinal bar on the bare floor pan to change resonant frequency if it's too noisy. Won't do anything for transfered sound but will help if the floor resonates like a drum head.
PNW_IPL (02-09-2020)
Old 02-09-2020, 11:06 PM
  #203
PNW_IPL
PNW_IPL's Avatar
So with the carpet about there was noticeable increase in noise. Road noise and exhaust drone. Not too bad, bearable for sure. With sound deadening removed road noise increase more but again not too bad. With the carpet back in, which I have not done yet and dont plan to until I'm certain drain tubes are fixed I can see one hardly noticing the difference. I did not do any of the trans tunnel or under console dash area.
just floor boards front and rear. Not under rear seats nor trunk.
Total weight was 3 pounds each side for a total of 6 pounds.
Joyryde (02-10-2020)
Old 02-10-2020, 12:41 AM
  #204
Joyryde
Joyryde's Avatar
If you want to remove some more, there is sound deadening tar on the transmission tunnel and underneath the rear seats as well.
PNW_IPL (02-10-2020)
Old 02-10-2020, 12:46 AM
  #205
PNW_IPL
PNW_IPL's Avatar
trans already makes alot of noise with the z1 mount and the kiddo rides in the back so that's a no go.
Old 02-11-2020, 07:52 AM
  #206
4DRZ
4DRZ's Avatar
That seems like a lot of work for only 6 pounds. I could see doing that in a race car, but a street car- probably not. Thanks for taking the time to do it. So was it dry ice that you used and how did that help with the removal?
Old 02-11-2020, 03:42 PM
  #207
slartibartfast
Dry ice makes the mastic brittle so you can whack it with a hammer and it shatters. Easy clean-up for the part that does so, some will refuse to part from the floor and then you have to use a heat gun to melt it, making for a somewhat gooey mess.
Old 02-12-2020, 11:44 AM
  #208
4DRZ
4DRZ's Avatar
That's a neat trick I will have to remember the next time I plan to gut a car of all excess weight.
Old 02-12-2020, 05:20 PM
  #209
Joyryde
Joyryde's Avatar
If you want to know another trick you can do with removal of the tar sound deadening in hard to reach areas, I would recommend getting a 5 gallon bucket and throw the dry ice block inside. Then, dump in a full bottle of isopropyl alcohol and smash the dry ice until it becomes a paste. Then you can throw the paste onto weird surfaces like the transmission tunnel.
The following 2 users liked this post by Joyryde:
PNW_IPL (02-13-2020), slartibartfast (02-13-2020)
Old 02-13-2020, 05:18 PM
  #210
PNW_IPL
PNW_IPL's Avatar
Thanks for that. Not too sure I want to remove the trans material as the vibration from the z1 trans mount is pretty bad as is.
Quick Reply: Sedan weight reduction
