Vibration at Idle
Vibration at Idle
2013 G37x, 53k mi.
When stopped with the car in drive there is a minor vibration that can be felt in the seat and steering wheel. With the AC on it's worse and can rattle the quarters in my center console. RPM's are stable and the vibration gets better if you shift the car into neutral.
The car didn't always feel like this and my mothers EX35 doesn't feel like this, so it's not "normal"
Any ideas?
Any ideas?
Had a similar problem.
https://www.myg37.com/forums/g37-sed...or-review.html
Check out the drive shaft section. It def caused vibration and after the fix, it went away. You can just crawl under car with a light to see if that same spot is torn where mine was
Mine does something kind of bizarre I get a rattle sound only when stopped at a light in D or DS that's when my RPM's are at 500, as soon as I put it in Neutral or Park it goes away because my RPM's go to about 600. Or even if I slightly rev it in D with my foot on the brake over 500rpm it goes away. Any thoughts?
Alright, just had my inspection, told them about the vibration, they checked the motor mounts and said it was in spec. Also, i'm apparently the only person who feels it (it is very minor).
Could dirty throttle bodies be the culprit?
Happens on my coupe when in drive but with brakes down or going in reverse. It's fine in park and N. Sometimes it faint while other times it's a lot. When I do turn on my AC it does vibrate even more. Hopefully it's not my AC compressor and Motor mounts or that would be expensive...
Did you ever found out why the car was doing that?
2013 G37x, 53k mi.
Any ideas?
Any ideas?
