Made the demon bolts my be-atch :)
Old 09-19-2017, 09:35 AM
  #76
takeapieandrun
takeapieandrun's Avatar
Yeah, with anti-seize I highly doubt you'll have an an issue. I should have used it, lesson learned the hard way for me huh hahaha. The threads on that o2 sensor were always a little suspect from the beginning
Old 09-20-2017, 06:47 AM
  #77
djdiskino
djdiskino's Avatar
Thanks for the pics! I’m going to hopefully tackle this before winter here in New England. I have the OBX RTP’s blnewt originally write a review on. I imagine my bolts are going to be terrible from the winters up here. Already made my concoction of tranny fluid and acetone 🙏ðŸ¼
Blk076MT (09-21-2017)
Old 09-20-2017, 04:38 PM
  #78
micafd3s
micafd3s's Avatar
are you still CEL free....
Old 09-20-2017, 05:04 PM
  #79
Received 4,941 Likes on 4,174 Posts
I am, if that's who you were asking
The following 2 users liked this post by blnewt:
Blk076MT (09-21-2017), micafd3s (09-20-2017)
Old 09-21-2017, 06:03 PM
  #80
Blk076MT
Blk076MT's Avatar
Originally Posted by takeapieandrun
Also.. during this whole process my passenger side o2 sensor inexplicably seized itself in the 3 months I have left the stock cats installed. I used a breaker bar on it and put so much torque the spark plug nut actually got rounded off. No idea how that happened as I didn't even tighten it that much last time because I knew I would be accessing it again. Maybe it got cross-threaded or something. There goes a night's worth at the bar for a replacement lol
Thank you so much bro, so the trick to steering shaftbolt is to use a 3/8 socket with a reducer from 1/2" to get enough clearance. I'll let you guys know how it goes.
Old 09-22-2017, 05:30 AM
  #81
takeapieandrun
Oh yeah, I used 3/8 all the way around. Also the u-joint helped with clearance.
Old 08-13-2018, 01:13 PM
  #82
m3clubracer
m3clubracer's Avatar
I am curious to know if anyone has used stainless hardware on the install in place of the plated fasteners? Do you know?
Old 08-14-2018, 03:01 PM
  #83
Received 4,574 Likes on 3,425 Posts
I went and bought stainless nuts & bolts for the rest of the catback, because it seemed like a good idea at the time.
But I didn't replace the bolts at cat flanges to the headers. Too much work to swap them out.
Old 07-04-2023, 04:01 PM
  #84
King300
King300's Avatar
hi guys, I attempted to install my resonated test pipes today. I was able to loosen every single bolt except for that one bolt that you have to access from the engine bay it’s the only bolt on the converter facing the engine bay, I was using long 1/2 extension and I was putting all my strength into it and I heard a popping sound and the socket slipped I think Iam starting to round it off so I stopped to get some help don’t know why ****in infiniti made it that way. Any recommendations on that special bolt? I was thinking of using heat like a torch but don’t know if I wanna get heat near that spot it’s very tight with Al out of sensors and wires around . Please let me know what to do for that bolt. I don’t wanna give up and take it to a shop after loosing all the bolts.
Old 07-05-2023, 01:22 PM
  #85
rotarymike
Moderator in Moderation
rotarymike's Avatar
The best option, if you're replacing the cats anyway, is to break that one off. I used a 1/2 drive 6-point socket, about 36" of extensions, and a 4' cheater bar and they broke fairly easily.
I know people say you have to unbolt the steering stuff, but all I did was unbolt and remove the air intakes and I had no problems getting around everything else.
Old 07-05-2023, 09:29 PM
  #86
King300
King300's Avatar
Thanks for the replay, the thing is I think I am starting to round off the bolt head and the socket is slipping when I try to lose it.do you think putting an impact to it is a good idea? or try and use heat?
Old 07-05-2023, 09:46 PM
  #87
rotarymike
rotarymike's Avatar
Skip the impact, it will just round off faster. 6-point socket with a piece of paper jammed in as a shim if necessary, long extensions and muscle.
