Hello from S.Fla
Old Aug 7, 2015 | 10:04 AM
  #46
xpcgamer's Avatar
xpcgamer
^^^You have the same tire specs I do. You are about the same offset but you got me by an inch in the rear (Please no joke here). I am planning on getting the Tein's and not lowering the rear. I have a feeling I will need to have some camber to get the wheel to tuck under the fender if I go to lower it. I have 2 small girls and 2 teenage niece's. I also tend to do all of the shopping in my car so that means loads of stuff in the trunk. I will not lower the rear if that means any rubbing out back.
Old Aug 7, 2015 | 10:14 AM
  #47
Rears are 19x10.0" +42, Michelin PSS 275/35ZR19
The rears poke. That's part of why I initially lowered the car, for the neg camber. However, the rear drop was too low for my preference, so I'm hoping to actually raise the rears to match the fronts (or thereabouts), at 26.75" floor to fender. Another 1/8" or so in rake won't kill me, as long as I can bring in the camber so there's no poke... hence the rear camber kit. I suspect having the rears at desired height with a -2.0* camber +/- will be a good target to shoot for. Right now things are whacked, (longer story), and the driver's rear is actually at -2.7* camber, with freakishly perfect flush fitment in the context of the height. When it comes back up, that kind of camber won't be necessary.
I have two girls, too. One teen, the other pre-teen. However, 99% of the time it's just me in the car, and rarely anyone in the back seat, with a virtually empty trunk.
Most of the poke is down the sidewall of the tire, because they're a pretty normal configuration, without stretch. And OMG obsessing over this crap is enough to drive you nuts! LOL
Old Aug 7, 2015 | 10:32 AM
  #48
Eventan's Avatar
Eventan
hey guys new to all this ...i was wondering if my 2009 g37x with no mods...can put this dimension of rim on it...17inch Silver BSA Rims with 215/45/17 tires
bolt pattern 5x114.3 et40
center bore 73mm .....and would it look good in your opinion,,,if you know what the better specs would be ...plz let me know...asap ...as i am looking to get rims very soon...thx,,,
Old Aug 7, 2015 | 02:17 PM
  #49
Er, what?
I distinctly remember thinking the Swift Springs were very much the same ride as OEM. If anything, they were actually a little more comfortable, if that makes any sense.
Are you suggesting my rims/tires could be hitting the rear fender lip with these Basis rear springs/shocks? That would be no bueno.
No, I'm saying the dampers will have full travel w/ the coilovers rather than OEM dampers that have a shortened travel since the lowering springs are shorter than OEM springs. Hope that makes sense.
Old Aug 7, 2015 | 02:38 PM
  #50
Oh-h-h-h. Because of the lowering springs, the OEM shocks are already depressed over an inch further in than they are intended to at uncompressed height. Whereas the Tein shocks are designed to operate similarly throughout the top 1.5" to 2.0" (based on the depth of the adjustment threads.) That's what you're saying, right? Now I understand.
OP, sorry if I've been whoring your intro thread. Seems like good discussion, though. And Org history, too.
Old Aug 7, 2015 | 04:23 PM
  #51
Evantan, shoot me a PM tonight and we can go over this, there's better options for sure
And sorry xpcgamer, I guess this thread is just a cool place to hang
And if you get the Tein Basis you'll have to lower the rear some, unless you plan on just using the front coilovers for now. I think if you were to lower it in the 1" range you should have camber you can live with as long as your toe is set OK. You should be OK as far as rubbing, I was right at the fender when I had my 295s and even hauling bags of concrete it wasn't a problem, granted I wasn't flying down the road but you get the idea.
Old Aug 7, 2015 | 06:00 PM
  #52
xpcgamer's Avatar
xpcgamer
blnewt what where you doing with bags of concrete in the back!?!
The seller I got the springs from allowed me to return them today. Once he gets them he will send me an invoice with the balance for the Tein Basis. I would love the lower the back 1" and the front a bit more. I'll start a "build thread" later tonight once I compile some pics.
Thanks for the help here.
Old Aug 7, 2015 | 06:51 PM
  #53
Well my truck got smashed into last year and there was a brief moment where that's all I could use, lol.
You won't have any problems w/ clearance since you're running the 9" rears w/ 275s. I'm dropped to 26.25 " in back (and front) essentially zero fender gap and run 10" +45 on 295s (previously) and now 285s, no rubbing or clearance issues and this is at -1.0 camber.
If you look at the Tein specs here (it says coupe but they're also the sedan springs)
TEIN USA | COILOVER KIT & SPRING KIT SEARCH ?INFINITI?G37 COUPE?2008+?STREET BASIS
The area shaded in green is the "safe range" for optimum performance and damper longevity. If you notice the minimum range is 1.4" front and 1" rear, this should result in a perfect mild drop w/ a slightly raked stance, I think you'd be very happy w/ that amount of drop, it will look right and be easy to deal with for daily driving.
Glad you were able to return that H&R set w/out issues.
Look forward to your build up.
Brad
Old Aug 7, 2015 | 08:34 PM
  #54
That's what sold me. All I want is a hair over 1" rear drop.
Old Aug 7, 2015 | 10:52 PM
  #55
xpcgamer's Avatar
xpcgamer
BTW guys this is the stance I am wanting. I know I don't have a Sport and I am not sure if he has 20"s but this is the look I am going for.
Who ever this car belongs too- to you.
Thanks
Old Aug 7, 2015 | 11:45 PM
  #56
Thanks
Nice look, that's about a 2" to 2.25" drop all around, so you're almost back to those H&Rs, lol.
Old Aug 8, 2015 | 06:06 AM
  #57
Yeah, that's pretty low. Easily a 2" drop, and not something I want. Fortunately for the OP, those CO's will allow him to dial it in wherever he wants.
BTW, that's Lorenzo's car... parked across no less than three handicapped spots like a boss.
Zoster is bagged, isn't he? Totally different ballgame.
