Jack stand mounting points
Old Feb 12, 2015 | 02:26 PM
G37Xtreme's Avatar
G37Xtreme
Originally Posted by jomak123
This has no chance to work as I am removing the tires, that's the whole point to jacking the car up on all 4 points. The hockey puck idea while nice has no chance of success with my jacks. As stated already you can't use the pinch weld itself with my jack stands, nor would I ever want to use a pinch weld.
I also tried just inside the pinch weld, if I recall, maybe we are talking different locations, but it started to buckle and I believe part of the plastic running board bottom is that area. I can go look again and post a picture.
The top layer of this contraption would be shaped different. It's modular, so you'd put a 4x4 on the top with a notch in it.
I'd rather support my car on all 4 corners by the tires than the frame. If the wheels don't need to come off, this is my preferred way, and with as little modification, a pinch weld connection can be achieved.
Here's a shot with a different topper, though I'd have a slot in mine. I'd also use more wood overall than he did.
Old Feb 13, 2015 | 08:17 PM
jomak123's Avatar
jomak123
Interesting, but I think I would use a 4x4 with a knotch and make sure it was beefed up. More work that I would want to do since I have jack stands though.
Old Feb 14, 2015 | 08:55 AM
G37Xtreme's Avatar
G37Xtreme
I'm working on hockey puck modifications so that my Jack stands can play nice on the pinch weld.
Old Feb 14, 2015 | 08:57 AM
AroundTheG37's Avatar
AroundTheG37
Mine arrived yesterday. Going to heat up a hanger and melt through it like butter. Going to be much better than using the OEM jack or using my own and deforming the pinch welds.
Old Feb 14, 2015 | 09:08 AM
G37Xtreme's Avatar
G37Xtreme
Are you making a Jack pad or a Jack stand pad?
Old Feb 14, 2015 | 11:26 AM
AroundTheG37
Jack pad.
Old Feb 14, 2015 | 04:24 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Is there a difference? I've used my pads for both.
Old Feb 14, 2015 | 06:15 PM
AroundTheG37
Depends on your style jack stands. Some are flat and some have a wide arch.
Old Feb 14, 2015 | 06:21 PM
quakerroatmeal's Avatar
quakerroatmeal
You could get these Esco flat top jack stands instead. I really want them as I hate when the stupid pinch welds deform as well.
Amazon.com: ESCO Jack Stand - 3-Ton Capacity, Model# 10498: Industrial & Scientific Amazon.com: ESCO Jack Stand - 3-Ton Capacity, Model# 10498: Industrial & Scientific
But 70$ for a single jack stand is steep IMO.
I have a long base low profile jack that I drive on 2x4 and jack the car up from the front sub frame. It's deep in there. Rear is easy like someone said from the diff.
Old Feb 14, 2015 | 10:44 PM
G37Xtreme's Avatar
G37Xtreme
I love those stands. I can't afford that coin for a stand though. The 3 ton Torin DOUBLE LOCK stands are on sale at Northern Tool for like $23-24 a pair. I bought two pairs, and used a $10 off coupon code. I am in the process of adapting something to work on the pinch weld right now.
Old Feb 15, 2015 | 10:57 AM
Lego_Maniac's Avatar
Lego_Maniac
Old carpet, with the hard backing works pretty good in the V notch of jack stands and the pinch welds. My "custom" ramps
Attached Thumbnails Jack stand mounting points-header-install-ii-128.jpg   Jack stand mounting points-header-install-ii-127.jpg   Jack stand mounting points-dscn2078.jpg
Old Feb 15, 2015 | 04:33 PM
I never trusted those pressed steel ramps, just seem so flimsy, and me being the DIY cheapsk8 I've used these hillbilly ramps for years. They work great, the cost is only 1 sheet of 7/16" OSB and a box of drywall screws. These are 8x36" w/ a 6" rise, if you use 1/2" wood it'll be about an inch higher. If you have a real low vehicle just space the wood further apart and make the ramps 4 foot although this will cause the price to skyrocket to about $20 total.
And when you stack them flipped and opposed it only takes up an 8x8 corner of the garage floor
Old Feb 16, 2015 | 01:30 AM
JSolo's Avatar
JSolo
Just say no!!!!!
I got 2 pairs of rhino ramps. For tasks such as oil changes where the wheels don't come off, I just jack up the front (K member) & rear (diff) ends of the car, placing a pair of ramps under the respective axles. This keeps the car level similar to having the wheels on the ground but ~12" up.
Old Feb 22, 2015 | 11:49 PM
  #29
Keroro's Avatar
Keroro
I want to confirm is something like this proper jack stand placement?
Where the stands are placed behind the pinch weld and going parallel to the car.
http://subaru.rockhopjohn.com/images..._jackstand.jpg
I already got a floor jack adapter that has a slit cut in it to allow the pinch weld to pass through for my hydraulic jack
Old Feb 23, 2015 | 12:27 AM
  #30
Here's a good thread on 35driver starting w/ VQsmiles' reply 23
Safe Jack Stand Placement - Page 2 - G35Driver
