Getting trolled by a knob
Old Jan 30, 2015 | 10:01 AM
ToXIc's Avatar
ToXIc
Getting trolled by a ****
trying to get my shift **** off and not sure what the hell... i've turned this thing counter clockwise 5 times and it still havent broken loose...
the puzzling part is that it looks like other parts are being turned around also..
Old Jan 30, 2015 | 10:05 AM
G37Xtreme's Avatar
G37Xtreme
I think Rochester had to use some pliers to get his off, but in your case, since something else is moving while you turn, it could complicate things further.
Old Jan 30, 2015 | 11:04 AM
How did you get your shift boot off while the **** is still there, and without lifting the bezel?
  • Two people.
  • One large channel lock wrench securing the shaft under the boot.
  • One large channel lock wrench to un-screw the ****.
  • A willingness to accept that the OEM **** will likely get trashed.
Some people get lucky, and can do it themselves, by hand.
Also, mine never "broke loose" as others have described. In fact, it never turned freely until the last couple of threads. And there are a lot of threads.
Old Jan 30, 2015 | 11:34 AM
ToXIc's Avatar
ToXIc
  • Two people.
the boot isnt off its just pulled up to show the rubber boot getting turned with the ****.. i wrapped my **** with an old leather belt then used channel locks but it still ripped/pulled the leather on the ****.. i guess i'll have to get a friend.
Old Jan 30, 2015 | 11:39 AM
Oh! So that dirty rag is actually the underside of the leather boot? I missed that completely. I suspect you've been slowly turning the **** on the shaft by hand, but I sure wouldn't be strong-arming that thing without securing the shaft while turning it.
Good luck, buddy.
Let's see pics of the **** you're wanting to install.
Old Jan 30, 2015 | 11:42 AM
ttv36's Avatar
ttv36
Race, repair, repeat.
After I ripped the leather on the **** I said fck it and put some vice grips on the top and eventually got it to break free. Be sure you are trying to turn it from the top and not the bottom.
Old Jan 30, 2015 | 11:57 AM
ToXIc's Avatar
ToXIc
i believe thats my problem i was turning at the bottom to middle...
Old Jan 30, 2015 | 12:00 PM
ttv36's Avatar
ttv36
^ Yeah that's the same mistake I made, it's not going to come off from that area. You have to turn it from the upper portion.
Old Jan 30, 2015 | 12:15 PM
ToXIc's Avatar
ToXIc
thx guys
37
Oct 17, 2020 11:12 AM
Ihtbealexxx
Feb 26, 2016 07:34 PM
Redfire32
Oct 1, 2015 04:49 PM
MaQG37
Sep 26, 2015 08:43 PM
Sep 25, 2015 01:38 PM
