Maintenance Socket sizes
Old Sep 30, 2014 | 03:48 PM
alxmlr789's Avatar
alxmlr789
Hey guys, I just bought a 3/8" impact wrench for maintenance and mods, and I am putting together an impact socket set. I bought deep socket SAE and Metric sets, but I know the car has some larger sizes than the set includes.
I've done a bit of research but can't find any definitive answers.
What are the largest that are used? I know lugs are 21mm.
Thanks in advance.
Old Sep 30, 2014 | 03:53 PM
canucklehead's Avatar
canucklehead
pretty sure a 21mm socket is going to be the biggest for routine maintenance components. caliper bolts are big, but closer to 17mm IIRC. and for that size and up i prefer a 1/2" drive, but then i don't have air tools. just good 'ol elbow power.
Old Sep 30, 2014 | 03:55 PM
Lego_Maniac's Avatar
Lego_Maniac
Originally Posted by canucklehead
pretty sure a 21mm socket is going to be the biggest for routine maintenance components. and for that size i prefer a 1/2" drive, but then i don't have air tools. just good 'ol elbow power.
+1 for 1/2" drive.
I'd also make sure to go with 6 point sockets.
Old Sep 30, 2014 | 04:22 PM
alxmlr789's Avatar
alxmlr789
+1 for 1/2" drive.
I thought that I read caliper bolts were upwards of 22-23. Could be wrong though.
I may be swapping the 3/8 impact for 1/2. The torque rating is 10ft lbs different. Not much.
Take a look, tell me what you think:
http://www.milwaukeetool.com/compare...&skus=2655B-22
Old Sep 30, 2014 | 04:35 PM
alxmlr789's Avatar
alxmlr789
Replacing brake pads Infiniti G37 sport brakes | G37 Akebono big brake pad replacement
Looks like the Akebono's have a 22 somewhere according to this DIY. Edit - that may be for the lugs.
Old Sep 30, 2014 | 05:07 PM
Lego_Maniac
Compare Products | Milwaukee Tool
Depending on what you're doing, that might not be enough. My 18 volt Dewalt impact driver wasn't doing anything on front shock through bolts. 1/2" breaker bar did the job.
I've only replaced the pads on my akebonos, but it reads like the caliper bolts are 22 mm.
Old Sep 30, 2014 | 05:16 PM
alxmlr789's Avatar
alxmlr789
I don't mind using a breaker bar for a little. I just absolutely despise taking wheels off without an impact. Especially with coilovers. Can't. Stand. It. haha.
I actually just cancelled my order for the 3/8" and wen't with the 1/2" Drive.
I'm realizing a lot of these bigger sockets aren't available in 3/8" anyways. Only 50 dollars more for the 1/2" drive.
Old Sep 30, 2014 | 07:33 PM
guy from norcal's Avatar
guy from norcal
might be hard to find smaller sizes like 10mm in a 1/2 drive.
maybe a cheap set from harbour frieght ?
Old Sep 30, 2014 | 08:03 PM
alxmlr789's Avatar
alxmlr789
I can get a 1/2 -> 3/8 reducer for the smaller ones. Should work just fine!
Old Sep 30, 2014 | 08:26 PM
Lego_Maniac
I use a flex head ratchet and sliding T handle with a 12" extension and deep well sockets for lug nuts
I'd be careful using an impact on a 10mm or even 12mm size bolts. Chances are they aren't torqued enough to require an impact and you risk breaking off the head. Don't ask me how I know this
JPat94
Sep 13, 2015 10:35 AM
ZSpeedPerformance
Supporting Vendors
Sep 4, 2015 11:09 AM
