Plastidip Lower Rear Bumper?
Old Aug 3, 2014 | 11:00 PM
GhostFaceKilla's Avatar
GhostFaceKilla
I'm sure a lot of people done this. Any tips? Do I need to prep or just mask the area around and spray the dip? Any negatives to the original paint? Thanks.
Old Aug 4, 2014 | 01:12 AM
35Sport's Avatar
35Sport
Clean the suface really well and don't wait more than a couple minutes before removing the tape for a sharp line.
Old Aug 4, 2014 | 07:42 AM
Paratrooper's Avatar
Paratrooper
Not hard at all, prep is key. like mentioned above peel tape while still wet, if your going to use multiple coats (recommended), then apply a few strips of tape on the edge to continuously peel after each coat.
Old Aug 4, 2014 | 12:25 PM
MiPwnYew's Avatar
MiPwnYew
I taped it off then did a few lighter coats near the bottom followed by a few heavy coats going up to the tape, then peel while it's still wet to get a nice clean line
Old Aug 4, 2014 | 02:53 PM
GhostFaceKilla
Anyone have pics of this actually done? The end result that is. Thanks!
Old Aug 4, 2014 | 06:44 PM
velocity1689's Avatar
velocity1689
could also consider a valence overlay, cost less than 50 )
g35srv107b.jpg Photo by BlueBatmobile2005 | Photobucket
Old Aug 4, 2014 | 09:13 PM
Paratrooper
Couldn't get photobucket up, search on here for mine.
Old Aug 4, 2014 | 09:35 PM
I had the rear valance area wrapped in flat-black vinyl. It turned out OK after having a second shop fix the botched job of the first. With hindsight, I should have tried Plastidip on my own. Failing that, I should have bought BlueBat's pre-cut pieces. Failing that, I should have had it professionally painted, or gone to a better shop.
Every time you mod the car, there are lessons learned.
In for pics of the OP's work.
Old Aug 4, 2014 | 09:48 PM
Lego_Maniac's Avatar
Lego_Maniac
I think hell might have frozen over. Did you just advocate plastidip
Where is Rochester and what have you done with him??
Old Aug 5, 2014 | 12:21 AM
Now that is ROTFLMAO
I'm a bit concerned as well
Old Aug 5, 2014 | 12:51 AM
dragion's Avatar
dragion
John's going senile in his old age...Call the Medics!
Old Aug 5, 2014 | 07:23 AM
For the lower section of the rear bumper? Sure, I'd try it there. Although I certainly wouldn't have high expectations.
You guys are so off-topic. Where's the Mod to clean up this mess?
Old Aug 5, 2014 | 08:26 AM
This thread hasn't migrated to something BMW related so carry on............
Old Aug 5, 2014 | 10:35 AM
GhostFaceKilla
I was looking at that, but is it me, or does the 06-09 G35's have a different rear bumper than the 2010+? The curves look different.
Old Aug 5, 2014 | 10:39 AM
Yes. They redesigned the bumpers in 2010.
IMO, changes in the fronts were a big improvement, but the '09 rear looked better than the 2010+.
