30K service yikes
Old Jun 18, 2014 | 11:09 PM
monty2003's Avatar
monty2003
Only thing I would consider doing is the belt and only if the ribbed side is showing cracks perpendicular to the ribs or if it is fraying. All of that other stuff is high margin profit for the dealer, completely unnecessary, and a total waste of money.
The only situation in which I would recommend the premium service intervals is if you drive the car very hard.
Brian
Old Jun 19, 2014 | 01:22 AM
JSolo's Avatar
JSolo
Just say no!!!!!
All of those except the ATF fluid can be done in your garage. The ATF requires special equipment to get the level just right. Assuming you have basic hand tools, floor jack, jack stands, etc, the cost is mostly in parts and time. Go synthetic if you're doing it yourself and plan on holding on to the car.
Old Jun 19, 2014 | 09:22 AM
G37CPA's Avatar
G37CPA
Here is what I consider the best answer: 36-month lease. Do your scheduled oil/filter changes and skip the rest of the kind of stuff the dealer claims need be done. Turn car in in 36 months, and lease another Infiniti. Extra incentives if you do a new lease as a lease customer. If you plan to but more than 15k miles on the car per year, then yes, buy and do all maintenance on schedule to extend the life of the car.
Old Jun 19, 2014 | 02:40 PM
malady's Avatar
malady
jazzmang is right. A/T are sealed and the fluid is good for the life of the car.
I might find a different dealer,this one seems to want to rip you off. my 02 cents
I would not keep the same a//t fluid for the life of the car.
And you can get it changed I just did at the dealer for around $120
Old Jun 19, 2014 | 02:44 PM
lightlypurified's Avatar
lightlypurified
dealers like to take advantage of those that don't know how to work on their cars, thank god for the forums.
Old Jun 19, 2014 | 03:35 PM
Glenn2008's Avatar
Glenn2008
Thanks to this forum, I have cleaned the throttle bodies, changed the serpentine belt, changed out the differential oil, transmission oil (6MT) cabin filter, oil changes, installed lighted kick plates and GT-R start button. I'm going to change out the brake fluid this fall before I put her away. I'll check out the pads at the same time, if they're down, I'll replace them. I may replace the antifreeze also. This site is OUTSTANDING! I also changed out the PS fluid. There's a DIY here on that, "a piece of cake."
Old Jun 19, 2014 | 07:52 PM
PERMAT's Avatar
PERMAT
I agree.
Changed mine last Saturday also. Randomly made an appointment and now at 48.5k miles, car feels better than when I bought it.
Old Jun 20, 2014 | 02:41 AM
lightlypurified
Originally Posted by PERMAT
I agree.
how many miles were you at when you decided to change your atf fluid? normally 50k would be the safe bet.
Old Jun 20, 2014 | 02:53 AM
Hapa DC5's Avatar
Hapa DC5
Brake fluid and diff fluid at 30k. Belts check if they are cracked, if not just wait until you see cracks develop.
The 7AT does not have a fluid replacement interval. We all know a "lifetime" fluid really isn't that so use your own discretion. I plan on changing mine at 60k.
Old Jun 21, 2014 | 09:18 PM
lightlypurified
just had my tranny fluid drained and filled at 41k miles by the dealer costed me 123 after tax, i asked the service rep regarding other fluids that needed to be changed he told me brake, power steering and drive belt needs to be changed at 60k and transfer case oil at 90k.
Old Jun 21, 2014 | 11:29 PM
Lego_Maniac's Avatar
Lego_Maniac
Pic of my 6MT trans fluid at ~18K. I can't imagine the auto being that much better.
Guess which is new vs 18K
Old Nov 11, 2014 | 09:54 PM
LaLa's G's Avatar
LaLa's G
Wow, the proof is in the pudding.
Old Nov 11, 2014 | 10:32 PM
Lego, back in June, at 19K miles, I had my tranny fluid swapped out for Redline MT-85. Now I don't have a side-by-side picture for pudding proof, but the OEM fluid was clean as baby spit, just like the new gear oil.
(We'll just pick this conversation right back up off the table, four months later. LOL)
Old Nov 12, 2014 | 03:32 AM
  #29
vqsmile's Avatar
vqsmile
Pudding? Proof???
Guys, manual tranny gear oil is nothing like auto tranny fluid. Just because it may have a darker color does not mean it's not still perfectly good. Unless you have tracked the car and know that the tranny temps were high enough to burn the oil, I wouldn't worry about a little color in oil that's been used less than 20K miles.
Old Nov 12, 2014 | 06:41 AM
  #30
Lego_Maniac
Beats me
Maybe mine is a result of all those 7500 rpm shifts??
