Question need your input!
Old Jan 21, 2014 | 08:39 PM
ChinkyChoy's Avatar
ChinkyChoy
Question Question need your input!
Alright so i m getting ready to throw down on a new set of kicks for the G.
this is how my car currently sits
But i think i want to go a little lower in the front dropped on BC coils. the current specs are 19x9.5 +35 all around. The wheels sit pretty flush with the fender line and i want to keep it like that.
The I am already in contact with Ravspec and these wheels can be made in any spec i want.
I have always had a square setup (LMGT4 and GT-S) should i keep these square or should i expand my horizons and go staggered (I have a 08 G35X)
the current specs i am looking at getting are 19x9 +25 all around will these be good? too aggressive? not aggressive enough? should i not run square anymore?
looking for inputs
Thanks!
Old Jan 21, 2014 | 08:55 PM
warped ideas's Avatar
warped ideas
A quarter past stripped
I've read the best offsets for sedans are between +36 & +45. I am currently running 20" X 8.5" +45 all around. Hope this helps
Old Jan 21, 2014 | 09:33 PM
JohnnyD's Avatar
JohnnyD
19x9 +25 would be about 4mm more aggressive than your current setup. So if you like the way it sits now this will be pretty close. As for staggered, your car is awd so non-staggered makes sense. I'm curious why you want to go down in width size?
Old Jan 21, 2014 | 10:29 PM
STownSaint's Avatar
STownSaint
Pics for reference? Curious how "flush" +45 offset is (TIA)
Old Jan 21, 2014 | 10:31 PM
warped ideas
Dunno? Check out my albums. I have some pics in there that can maybe help answer your question.
(TIA)
Old Jan 21, 2014 | 10:46 PM
ChinkyChoy's Avatar
ChinkyChoy
i wanted to go down in width because i noticed some tire damage on the inside of my front tires i m not exactly sure where its from but it looks like it might have to do with when i turn its rubbing on something.
thanks for the reply yeah i want to go a little more aggressive then what i have now. i ll probably go with some less tire and more camber
here are some side shots
https://scontent-a-dfw.xx.fbcdn.net/...65424382_n.jpg
Old Jan 22, 2014 | 02:05 AM
Well Natalie was running 10.5 +45 square setup on stretched 255s, I think if you want a standard tire fitment I'd go w/ 9" +35 running 245 or 255 tires.
Old Jan 22, 2014 | 09:04 AM
Paratrooper's Avatar
Paratrooper
the rubbing your getting could be from the drop, I would check all that out before making purchases... so you dont mess up any new kicks.
Old Jan 22, 2014 | 10:21 AM
ChinkyChoy's Avatar
ChinkyChoy
I saw her setup and its really sweet, but shes a little lower than what i want to do. i think i am going to go with 9''s since the 9.5s are hitting something when i turn all the way. i just need to figure out the best offset and a +35 to +25 is what i am looking at.
for sure i ll check it out. i m putting in new brakes this weekend so i ll have all the wheels off the car to double check wtf is going on i saw it the first time when i went to put the akebono templates in.
Old Jan 22, 2014 | 11:25 AM
Sunny G's Avatar
Sunny G
My car is a little lower than yours and I'm running 20x9 +20 in the front with no rubbing issues. If you feel that it will rub just add some negative camber
Old Jan 22, 2014 | 04:38 PM
ChinkyChoy's Avatar
ChinkyChoy
do you have any pix?
thanks!
Old Jan 22, 2014 | 05:09 PM
botlfed98's Avatar
botlfed98
why would you want to go any lower??
Old Jan 22, 2014 | 05:11 PM
ChinkyChoy's Avatar
ChinkyChoy
front is a little high compared the the rear IMO
Old Jan 22, 2014 | 05:29 PM
warped ideas
Just to let you know OP if you didn't already know this, the sedan and coupes have different factory offset specs. I didn't know this until Blnewt (knowledgable man) chimed in when I was asking questions about "the right" offsets for my G. Just trying to make sure you don't take any coupe owners specs to heart in regards to your sedan.
Old Jan 22, 2014 | 06:04 PM
ChinkyChoy's Avatar
ChinkyChoy
well aware of the coupe and sedan offsets thanks tho
the more i look at it the more i think i m leaning towards +25 or around there like what was mentioned above nothing that a little stretch or camber cant fix
