Question need your input!
i wanted to go down in width because i noticed some tire damage on the inside of my front tires i m not exactly sure where its from but it looks like it might have to do with when i turn its rubbing on something.
thanks for the reply yeah i want to go a little more aggressive then what i have now. i ll probably go with some less tire and more camber
here are some side shots
https://scontent-a-dfw.xx.fbcdn.net/...65424382_n.jpg
Here is my car when I tried to run standard size tires. The front fit pretty good 245/40/19x9 +25 and -1.5 camber rubbing the outside of the fenders on inclines when turning the wheel all the way (probably wouldn't be an issue if your set higher). The rear rubbed like hail even at -4 camber 275/35/19x10 +25. I ended up moving the 245/40 to the rear and getting 225/45 for the front.
redlinernyc
Feb 29, 2016 11:06 PM
nomorecivicsi
Sep 10, 2015 03:58 PM
