Sedan Chat Thread
Old Dec 22, 2017 | 05:10 PM
  #12031
future62's Avatar
future62
Originally Posted by jpg37
I have a tuner and can adjust the timing on the fly, would I get much gain from advancing the timing and running 100 octane fuel?
Do you get any feedback on knock? If so probably best to get a tank of 100 octane and find out very gradually.
Old Dec 24, 2017 | 12:31 PM
  #12032
carguy95's Avatar
carguy95
Changing Spark Plugs
How often should the spark plugs be done on the G? Also, how hard is the DIY, and what else do you need besides the actual plugs?
Old Dec 24, 2017 | 12:36 PM
  #12033
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
You can just follow the factory schedule for plugs. If I remember right they say to check them at 100k km and replace if necessary. Don't quote me on that bit.
The DIY isn't too bad. Need your usual sparkplug socket. Extension for your ratchet, it's a deep reach. You'll have to remove your throttle bodies to access the back plugs. This is a good time to clean them too, just make sure to do the idle relearn afterwards. Besides that, just some hoses in the way. I'd say difficulty is 5/10.
Old Dec 24, 2017 | 01:26 PM
  #12034
carguy95's Avatar
carguy95
Can you elaborate on the idle relearn? So after I clean the throttle bodies, just start the car and let it idle until it normalizes or...?
Old Dec 24, 2017 | 01:32 PM
  #12035
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Ive always had my friend at Infiniti do it for me, but this should help: (coupe/sedan, same procedure)
2008-2011 Infiniti G37 Coupe Idle Air Volume Learning Procedure | Infinitihelp.com
Old Dec 24, 2017 | 01:56 PM
  #12036
carguy95's Avatar
carguy95
Thanks, that's interesting. Will post a detailed summary of the DIY (in the appropriate thread) when I get around to doing it.
Old Dec 26, 2017 | 09:28 AM
  #12037
jpg37's Avatar
jpg37
No, but I believe the knock sensors would detect detonation and retard timing if that occurred. I will try and gradually increase the timing to see what results I get. I will keep posted once it warms up -7° this morning.
Old Dec 26, 2017 | 01:12 PM
  #12038
Epiphany's Avatar
Epiphany
Forgot how sad my car is once it gets to -30 outside. Hell of a noise starting up, backup cam doesn't work when it's that cold, head unit is super slow and sad. Also get lovely warning lights on the dash once it gets this cold, today was flashing SRS light, security indicator light and the intelligent key warning light. Car still drives fine and everything works with all the lights turning off after a restart once the car has warmed up.
Old Dec 26, 2017 | 04:54 PM
  #12039
slartibartfast's Avatar
slartibartfast
While the difference is academic at that temperature, I assume you mean -30*C, being Canadian.
Old Dec 27, 2017 | 11:14 PM
  #12040
Epiphany's Avatar
Epiphany
Ah yes, -22F. Car wouldn't even start with my remote starter this morning, had to go out there and push the button and then run back inside. Wasn't sure that it was going to actually fire up with how slow it cranked.
Old Dec 28, 2017 | 02:10 PM
  #12041
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
Well do you blame the car!? Thats cold AF outside!
Old Dec 30, 2017 | 03:13 PM
  #12042
STownSaint's Avatar
STownSaint
Anyone know if the center caps for G37 and Q50 are interchangeable?
The Q50 comes with center caps with a nice black logo that I think looks much sharper than the ridged, chrome look that the G37 ones have.
Old Dec 30, 2017 | 10:13 PM
  #12043
slartibartfast
I thought someone posted about this a few weeks ago?
Old Dec 31, 2017 | 09:36 PM
  #12044
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Since its starting to hit us soon, Happy New Year ya filthy animals!!!
Old Dec 31, 2017 | 10:09 PM
  #12045
Epiphany's Avatar
Epiphany
Got down to -28F with a windchill of -39F. Battery called it quits. Had to get a boost since my portable battery booster was also dead... Going to have to grab a new battery now.
