Bird poop on door handle!
I woke yesterday morning and I had bird poop splattered on the center of my driver side door handle...I couldn't believe it landed right on the door handle, as it was ironic as I never even usually get bird poop on the car at all.
It was only on the middle of the handle, so I was able to open the door without touching it at all.
Last night it rained and it's completely off the door handle, which is pretty awesome...Although I'm still worried about any germs or potential diseases being spread on there?
What would be the best to use to disinfect my door handle? Can I use lysol or chlorox disinfecting wipes? Are these safe to use on the car? Or just a sponge and car wash soap? I want to make sure non of the poop is still on there.
Thanks!
Brad
Thanks!
Brad
A good old car wash with soap and water will do the trick but if your really worried about any diseases then use a towel with rubbing alcohol like BB stated above and that should sanitize your door handle.
I would wash the entire area with straight bleach and then sand the spot with 200 grit sand paper to make sure any remaining poop has been removed from the pores of the plastic handle. OP should wear safety glasses, rubber gloves, and and throw away coveralls. This is an extremely serious situation deserving extraordinary caution. This same approach can be used to remove disease carrying bug splatters from the front bumper.
