Rear Wing Roof Spoiler by ShadowSpeed
Old May 7, 2013 | 07:48 AM
Originally Posted by dragion
Thanks guys for all your opinions/comments...both positive & negative.
Sorry about that, buddy. All I can say is, if someone bothers to say why they don't like something, then it's only right to explain the reasons without being a d1ck about it. (Still working on that second part.)
I suspect it would add to the process if I were to see it in person. Although I have no idea whether that would be good or bad.
Old May 7, 2013 | 08:54 AM
Thanks for the tip!
Did you use the supplied 3M promoter?
I didn't because it would have dried before I would be able to align the spoiler correctly.
I wonder if the 3M promoter is similar to the 3M 94 Primer, I just used the primer on my last vinyl grill wrap and it really made that vinyl stick w/ about 3x the force.
That's the main reason I haven't done the roof spoiler, I've heard that the fit is tough to get 100% right (even the top brand names), and the double sided tape doesn't hold it completely tight over time. Maybe the 3M promoter would be just the final piece to get everything fitting, and staying, just right.
I do like the subtle look, I think it would be a nice combo w/ the F&R OEM spoilers.
Old May 7, 2013 | 12:28 PM
dragion's Avatar
dragion
No apology needed...I greatly appreciate your honest opinion!
I asked for members thoughts & comments and that is what I expect..."their" opinions.
Keep them coming....
Old May 7, 2013 | 12:35 PM
rks's Avatar
rks
I like mine. No complaints for $65.
Old May 7, 2013 | 01:35 PM
sniper27's Avatar
sniper27
3M Automotive Trim & Accessories : 3M
I used this one on my rear diffuser and I can say, that thing is not coming off without using an extreme amount of force.
Old May 7, 2013 | 01:42 PM
dragion's Avatar
dragion
I found this from 3M's website:
3M™ Automotive Adhesion Promoters
An adhesion promoter or primer is most commonly a resin system in a solvent-based carrier and is used to alter the surface characteristics of a substrate prior to tape application. This surface alteration enhances, or in some instances creates a modified surface for bonding with a particular pressure sensitive adhesive. Adhesion promoters are most often used to raise the substrate surface energy of low surface energy plastics such as TPO, PP, PPO, PC, ABS and other plastic blends/alloys, allowing for increased short and long-term adhesion levels of 3M acrylic foam tape adhesives.
3M™ Adhesion Promoter 2262AT is specifically formulated to be used with 3M™ Acrylic Foam Tapes for automotive applications. The adhesion promoter should be dry before applying the tape. For best results, apply tape within one hour after primer application. Be sure the primed surface remains free from contaminants prior to tape lamination.
I've researched and found that majority of people who installed either roof or trunk spoilers didn't use the promoter...either decided not to (like in my case) or didn't receive any within their kits.
I've read that some had no problems with the supplied 3M dbl-sided tape and other just wouldn't stay adhered to the either the spoiler or the vehicle.
I installed a similar type of spoiler on my FX and it held up without any incidents...no promoter, just 3M dbl-sided tape.
I'm hoping that mine will be fine.
Old May 7, 2013 | 01:49 PM
dragion's Avatar
dragion
Nice price!
Pre-painted with shipping?
Old May 7, 2013 | 02:38 PM
rks's Avatar
rks
Nice price!
yes, it's the same Ebay one but I purchased it well over a year ago and finally installed it about a week ago. BTW my wife didn't like it but she prefers OEM .
My next change is to swap the chrome trunk piece for body-colored.
Old May 7, 2013 | 03:13 PM
dragion's Avatar
dragion
If there was an OEM one by Infiniti, I would have considered it too!
I think for an inexpensive product from China, it's not bad as far as quality & fitment... it's only a roof wing spoiler.
As I mentioned, this spoiler doesn't look off from the Infiniti rear lip spoiler and goes well with it.
Old May 7, 2013 | 07:36 PM
dragion's Avatar
dragion
A few more mobile pics...
Old May 7, 2013 | 08:58 PM
Well... I'm digging this B&W photography right here. And that 4DSC decal looks fantastic
Old May 8, 2013 | 12:20 AM
This pic right here makes me want one now~and agree, the 4DSC is looking hot But remember dragion, I warned you about that sticker and the further costs associated w/ it
Old May 8, 2013 | 12:53 AM
dragion's Avatar
dragion
Brad, I know...I know!
That darn sticker is just like a "Lays" potato chip...you just can't mod once!
Old May 8, 2013 | 09:00 AM
  #29
true that ^^^
IMO your car would look just right w/ my window trim DIY & Rochesters duck-feet black-out wheel idea. Since you're on a DIY modding roll right now I think it's "your time"
Here's a pic of Rochesters wheel plan
https://www.myg37.com/forums/3617431-post18.html
And my trim wrap DIY
https://www.myg37.com/forums/d-i-y-i...-g-sedans.html
Old May 26, 2013 | 07:51 AM
  #30
MyBeast's Avatar
MyBeast
Seems like a few of us bought them already from eBay nd are liking it. It's time for me to pull the trigger as well.
