Today is the magic day
Here it is.... The right rear is off some but they guy *john told me
her would not worry about it being that is not much and would
not get a camber kit. What do you guys thing... This is with the
swift springs i had installed one week ago. 1.3 in the front 1.0 in
the rear. #gopats #playoffs
Your rear right toe is way off, you should at least get a rear toe kit or your tires will really shred quick.
get just one for the rear? and how much would i be looking at spending for a good brand?
If your camber is close it's not too bad but if your toe is out then you need to get it fixed. Toe bolts aren't very expensive (well under $50) but you do have to do some drilling to get them installed. I'm not able to read your alignment but I find it odd that your toe is out just from springs.
I would have them re-set the rear left toe. They may need to increase the camber a little to improve the toe but it would be better.
It's a blurry pic - what did they set the front right camber at? Is it greater than -2.0? It shouldn't be.
For comparison my car is lowered a bit more and they set my rear toe at 0.11L & 0.15R. The camber is -1.8L & -1.7R.
The fronts are a little bit adjustable. They managed to get my toe, both sides, too 0.05 with the camber around -1.7
Edit: no after market camber kits
Front Left Camber-.2 Right -.1
Front Left Toe .05 Right .03
Rear Left Camber -.6 Right -1.0
Rear Left & Right Toe .08
I should have wrote that mine is without any camber kits. All OEM arms and bolts....Edited above
So there was another way to do it without issues should I make them do it over??
KZK
Canada
Sep 16, 2015 10:00 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
Blue_Batmobile
Interior/Exterior Items
Sep 4, 2015 11:45 PM
KZK
Canada
Sep 2, 2015 05:30 AM
