Is it really necessary sitting engine on a cold winter day?
Old Dec 7, 2012 | 12:17 PM
g37guy01's Avatar
g37guy01
You didn't actually read this article, did you?
I read it and I agree that unnecessary idling wastes gas. However, all of us have our own definition of unnecessary. Stated another way, I only let my car idle the necessary amount of time in which I believe I can drive safely while at the same time imo, the drive train can handle normal driving situations based on the outside temperature.
Old Dec 7, 2012 | 02:37 PM
blazeplacid's Avatar
blazeplacid
I let the cars beeping and self checks complete themselves and then go.
Usually 10 seconds or so.
Old Dec 7, 2012 | 04:14 PM
canucklehead's Avatar
canucklehead
i find the time it takes to belt up, adjust radio, adjust heat, set info screen, turn on lights, etc, takes a good 30sec or so. at this point the revs have dropped (if not freezing cold) so driving off is fine. then it's an easy drive for the first few mins. "waiting" ~30-60sec is not a nuisance, nor do i think it is excessive. allows for engine oil to flow which is important for wear & tear.
if it's sub-zero temps then a bit longer is reasonable, but not much. usually scraping windows takes longer - for those unlucky enough to park outside.
Old Dec 7, 2012 | 04:25 PM
2011G37JOHNBEST's Avatar
2011G37JOHNBEST
I did a test yesterday after work around 6:00PM , temperature about 60F, Southern Cali
when the needle actual drops it doesnt pass below 1 but stay at 1, (while started the car it's about up rev above 1, so what about you guys?
Old Dec 7, 2012 | 04:35 PM
2011G37JOHNBEST
Originally Posted by canucklehead
common sense tells me that an extended warmup (5-10 min) is overkill and unnecessary, however if it's frosty out a brief warmup (~1-2 min) to allow proper lubrication circulation is wise. then, once starting out driving, take it easy until all other driveline fluids are up to operating temps.
i park in an unheated garage and usually go with a 30sec "warmup" before pulling the car out, but it doesn't get very cold here. and my first few kms are primarily downhill which allows a good warmup period.
Yeah , I think sometimes "common sense" stays true.
I recall read an article a few month ago, saying it's unnecessary for car to warm up because our cars are relevant modern, it's kind of like some articles claiming eating eggs' yolk are bad for you, but it's actually contains protein which is good for memory build. sort of off the topic but common sense stays true.
Old Dec 7, 2012 | 09:13 PM
monty2003's Avatar
monty2003
I always wait until the temperature gauge stabilizes to drive it hard but I usually start it, wait 10 seconds and go. The exception is when it is very cold here in Chicago (close to zero or below zero). When I start the engine it makes a distinctly different noise - almost like a moan. In those cases I will let it warm up for a minute or so until noise goes away. Modern multi viscosity oils flow well at lower temperatures so oil flow isn't a huge problem.
Ever try to turn over an engine at very cold temperature with single viscosity oil grade 30 oil (i.e. a lawn tractor)? If it's too cold, it wont happen!
brian
Old Dec 7, 2012 | 10:21 PM
dal1307's Avatar
dal1307
Originally Posted by hinomura
Every car mechanic I have ever talked to, every car magazine that I have ever read, have all said that you should at a minimum warm your car up from 30 secs to a minute. With respect to our particular car you want to warm it up until the RPMs drop from 1500 to right above 1000. Also like canucklehead said, even after you warmed it up for a minute, you want to take it easy on the car until the rest of the drivetrain components warm up as well. I generally wait until the RPMs drop to 1100ish then drive real easy for about a mile or two. I also get the same transmission jump that CRV_33 gets if I try to start driving too soon before the engine warms up, just lets me know to go back into neutral and wait another 30 seconds.
TL;DR - Waste 30 seconds every day for 10 yrs or waste 2 weeks plus hundreds if not thousands of dollars 10 years from now when your car is in the shop. Your choice.
That transmission jump is because the engine is still running at fast idle. With modern oil you should not have to warm up the engine for a significant amount of time unles you are in an extremely cold climate. 10 to 15 seconds to allow the oil to circulate is plenty as long as you drive normally until the engine reaches operating temperature (normally meaning not romping on the car, WOT etc.). Actually starting the engine cold is the harshest environment as the oil has all drained into the pan and you are relying on the thin coating that is left on the engine components to protect your engine.
Old Dec 7, 2012 | 10:32 PM
financeman's Avatar
financeman
brian
Yep....I do the same thing and have for my entire life. With low viscosity oils long warms ups are not needed or necessary.
Old Dec 10, 2012 | 02:06 PM
turbojay's Avatar
turbojay
brian
I agree with you 100%. Start the car, wait 10 seconds and go slow for few blocks. On extremely cold days, let the car idle a little longer but still under a minute. I have noticed the engine warms up much faster when the car is moving instead of letting it idle for 5-10 minutes. Been doing the above all my life, never had any issues with any of my cars.
Old Dec 11, 2012 | 10:49 AM
G37CPA's Avatar
G37CPA
^ This. Exactly.
Old Dec 14, 2012 | 01:21 PM
thebals's Avatar
thebals
I have a 20 mile drive one-way to work. I usually start my car and wait till the rpm needle drops down to 1000. Then I start driving and take it easy till I hit the freeway (about 1 mile) and by that time the engine temp needle usually has reached its stable position that it stays at till I get to work.
Old Dec 14, 2012 | 01:27 PM
snowtan's Avatar
snowtan
Originally Posted by chuckie311
check out this article.. i get in my car and go..never wait for it to warm up
Should I Let My Car Warm Up Each Morning?
makes sense to me
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
NGRBabies
Mar 25, 2016 12:38 AM
reigle9
Aug 6, 2015 02:45 PM
