Update 2. Z1 tubes installed just an FYI I'm not sure about the other tubes hps for example but the finish on the z1 tubes wasn't exactly what I expected. Instead of it being a smooth black tube. It somewhat looked like it would look If it was covered in electrical tape if this makes sence. Just letting anyone that reads this know since I personally wanted as clean as possible look.
I like the tubes...but aren't they supposed to have some clamps on them?
Otherwise - looks good!
Weight reduction...no honestly mine didn't come with clamps and it's so snug a fit I never really worried about it. I guess I should email z1motorsports about it and find out for sure.
Better safe then sorry...mine are a tight fit (very tight), but still wouldn't want to risk having it come loose due to the air pressure!
Worst comes to worst, just use the stock ones if Z1motorsports don't send you any.
Weight reduction - hahahahaha
Correct - they didn't come with new clamps. BUT - you probably should re-use the OEM ones. Those tubes go through a lot of heat cycles - and could loosen up with time. Having one slide off would be no fun...
