What this noise my engine is making [vid]
Old Nov 2, 2012 | 03:51 PM
derekc89's Avatar
derekc89
I noticed a strange noise coming from the enginer after driving it today. I have another g37x too and it doesnt make that noise. Any thoughts?
[yt]http://youtu.be/S40feYSKUxk[/yt]
Old Nov 2, 2012 | 04:16 PM
ONEighty's Avatar
ONEighty
Check your oil levels. Sounds like a bit of engine knock.
Old Nov 2, 2012 | 04:38 PM
derekc89's Avatar
derekc89
Thanks for the response 180. The noise went away once I restarted the car.
Old Nov 2, 2012 | 05:40 PM
monty2003's Avatar
monty2003
If you hear it again, the best way to diagnose is with a mechanic's stethoscope. If you don't have one you can use a big screwdriver - place the tip on various engine parts and place the handle end firmly against your ear. You'll be able to hear the source of the knock. To do it thoroughly you may have to remove shrouds and even get the car on a lift or on jackstands with the engine running to get at all of the necessary components. Beware of moving parts!!!
One time I had a knock that sounded like the knock in your video and it turned out to be a fractured serpentine belt slapping aginst the idler pully.
Have head fuel rails on older Gs make similar noises and even belt tensioner bearing pulleys going bad have made similar noise altough they sound more like a rattle.
Brian
Skyaddict
13
Nov 8, 2018 07:14 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
91dx
Aug 1, 2016 10:46 PM
Wikedg37s
May 27, 2016 11:24 PM
Grayg37s
Sep 27, 2015 03:12 PM
