Intelligent Key Stuck
Old Oct 7, 2012 | 05:16 AM
ashmostro's Avatar
ashmostro
I'm guessing you also TURNED the key after you inserted it, thinking you were supposed to (you are not... This is not a key hole.
If you did, turn it back and then remove it. Either way, you probably did some mechanical damage to the car, so get it checked out even if you do succeed on removing the key and starting the car.
Good luck and let us know how it goes.
Old Oct 7, 2012 | 01:17 PM
NJ Torque's Avatar
NJ Torque
This is not a warratable failure... The I-key reader(slot) is about $350...
Old Oct 7, 2012 | 01:34 PM
telcoman's Avatar
telcoman
Originally Posted by Mattster
I did not know that.
Learn something new every day
Perhaps you should take the owners manual into the bathroom and spend some quality time reading it
Telcoman
Old Oct 7, 2012 | 01:57 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^Some of the best ideas originate from that room!!
Old Oct 7, 2012 | 02:12 PM
Lions81's Avatar
Lions81
Thumbs up thank you +1
Originally Posted by dkmesa350z
A switch inside the glove compartment disables the fob trunk release and dash trunk release.
Had to give you a point for that, great information.
Old Oct 7, 2012 | 03:53 PM
blackhawksfan81's Avatar
blackhawksfan81
LBJ planned the Tet Offensive in there after a bad Chinese meal.
Old Oct 7, 2012 | 07:05 PM
Saltin's Avatar
Saltin
My wife did exactly this one time when I leant her my car. No idea why. It was a bitch to get out, but it is completely possible to gently remove it. I used a long thin wooden stick you'd use for a shishkabob and gently pushed up the part inside the hole that grabs the fob.
philttz
Feb 17, 2016 11:26 AM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
Cmedlin96
Sep 20, 2015 11:09 PM
