Gas mileage on dash different than navi screen??!?
Old Jun 23, 2012 | 11:17 AM
squal17's Avatar
squal17
Why does the mpg scale on the dash go to 0-60 mpg buy when you view it on the big center navi screen it only goes from 0-30 mpg? When I am coasting on the highway it be getting more than 30 mpg. I also noticed that I have different avg. mpg. reading on both...no surprise that my mpg reading on my dash display is higher by .5 mpg. Any thoughts?
Old Jun 23, 2012 | 11:57 AM
Coprolite's Avatar
Coprolite
They are two different measurements. Difference between them is due to different reset times. I use the dash for long term average and the navi screen for each tank fill.
Old Jun 24, 2012 | 01:15 AM
jddssc121's Avatar
jddssc121
i do almost the same
center for long term, and Navi for each OCI
Old Jun 24, 2012 | 09:24 AM
fyiegyptian's Avatar
fyiegyptian
Good idea! I always reset the dash every time i fill up. I'll try this way now
Old Jun 24, 2012 | 03:53 PM
squal17's Avatar
squal17
No as concerned as they read different numbers but why does one go to 60mph and the other only to 30... One of them is not going to be right
Old Jun 24, 2012 | 04:47 PM
DeamonG37s's Avatar
DeamonG37s
Jus a different scale of measurment
Old Jun 24, 2012 | 08:24 PM
mikeb2004's Avatar
mikeb2004
Ok....... Neither of them is "wrong", they are both right.
Here is why you are seeing two different numbers: One of the displays is short term and one is long term. There are two separate places to reset them. If you'd really like them to both show the same number (thereby losing the long term average), then you can reset them both at the same time.
The fact that the display only shows 30 doesn't change the numbers it works with.
Think of it this way:
If your speedometer only goes to 100mph, and you drive 110mph, sure it may stop at 100 on the gauge.... but it still doesn't change the fact that you're actually going 110 and your odometer will change accordingly, (i.e. it's not going to ignore the fact you're going 110). Similarly, the fact that the gauge display runs out at 30 doesn't change the measurement it is taking to compute the average MPG....... of course.
But none of that is actually relevant to your original question.... The displays are different for the reason mentioned above. You're attributing the display difference to the reading difference, but it is actually two different averages, nothing to do with the display it shows you.
Hope that helps
Old Jun 25, 2012 | 07:05 PM
squal17's Avatar
squal17
Hope that helps
Yes!!!thanks for your answer...one last question... which is the short and which is long term because there seems to be different answers to that in this forum....
Old Jun 25, 2012 | 07:45 PM
Coprolite's Avatar
Coprolite
The one that you reset the most recently is the short term MPG. I recommend that you use the navigation for this, as it keeps a history of past values before the resets. The one in the instrument cluster works best for long term tracking as it has no history.
Old Jun 30, 2012 | 09:05 PM
blackhawksfan81's Avatar
blackhawksfan81
One uses the speedometer and one uses the GPS calculated speed. It says this in the manual.
linvbro
Aug 22, 2016 01:25 PM
rob145
Mar 28, 2016 01:28 PM
si_driver
ECU Tuning / Dyno Data
24
Sep 29, 2015 11:38 AM
m3clubracer
Sep 28, 2015 03:45 PM
John B
Sep 27, 2015 11:41 PM
