My Up Coming Project
Old Mar 19, 2012 | 06:43 PM
  #31
soundmike's Avatar
soundmike
Took it off in a few hours, didn't like how it looked.
Old Mar 26, 2012 | 12:11 PM
  #32
qpham45's Avatar
qpham45
Ok so here is the spray gun that i will be using to spray the pre-thinned plasti dip.
Old Mar 26, 2012 | 12:43 PM
  #33
dagon68's Avatar
dagon68
Subscribed
Old Mar 26, 2012 | 12:44 PM
  #34
When are you going to do this? Even though I am a charter member of the Plasti Dip Haters of America Club, I hope it turns out good for you and I'm interested to see the results. Are you doing this at home yourself or having a paint/body shop do it?
Old Mar 26, 2012 | 01:57 PM
  #35
soundmike's Avatar
soundmike
Hmm... i think you're better off with a real spray gun powered by a compressor. Reviews of this Wagner have been mixed and have trouble with certain products which has similar consistency to PD.
But if you can get it working, kudos!
Old Mar 26, 2012 | 02:27 PM
  #36
qpham45's Avatar
qpham45
Yeah, Mike, I read the reviews of this gun and it seems to only work well with thin fluids. But I did talk to Fonzi from dipyourcar.com and he personally recommended this gun for the already pre-thinned gallons of plasti-dip. But if it doesn't work well I can still use it to paint my fence and walls, LOL. Wish me luck man.
Old Mar 26, 2012 | 02:30 PM
  #37
qpham45's Avatar
qpham45
LMAO!!! YOu are something else, Jeremy. Yeah I'll be spraying this in my garage. I hope this turns out at decent since this is the first time. I'll keep you posted.
Old Mar 26, 2012 | 03:44 PM
  #38
qpham45's Avatar
qpham45
So i changed my mind on the color. It will no longer be red. I will be spraying it a gunmetal grey this weekend. I'll post step by step details and photos along the way.
Old Mar 26, 2012 | 04:25 PM
  #39
soundmike's Avatar
soundmike
Can't wait! I'm very curious about this and may try it on my kids power wheels. Good luck!
Old Apr 2, 2012 | 11:28 PM
  #40
qpham45's Avatar
qpham45
So it begins. I am have started on the long process of plastidipping my car. The first part that i am beginning with is the chrome window trim. I know a lot of people out there have wondered how to black out the trim other than vinyl wrapping it. The only other member that I know that's plasti-dipped their chrome trim is Cereal2K.
Ok so the first step is figuring out what you will need. 1)Plastidip (I used 1 1/2 cans) 2) painters tape 3) razor blade 4) Optional - I used the comfort grip for the spray can.
Than you will need to cover the windows. There is a small trick to tapping these up. You will need to cover half of the upper and lower weather strip along the windows with the painters tape so that you when its time to remove the tape the plastidip will cut along the premade gaps that the window and weather strip makes. And also you will be able to peel it back if the cut isn't as smooth as you would like it.
Another thing is to leave about a quarter inch gap between the bottom chrome trim and the tape. Its ok that the paint shows. That is what you want.
Now its time to paint. Remember that the first coat does not need to cover the chrome trim 100%. BUT you do need a nice think enough coat where it lays down wet. You have a very small forgiveness zone when spraying with plastidip. About 5"-6" is all you will have. If you spray any closer the platidip will run. If you spray to far away the plastidip will not bond right leaving you with the gritty sand paper feel when it dries. Believe me, I found out the hard way. You want a super smooth finish when it dries so 5"-6" spray distance is all you will have. Leave the plastidip to dry for 30 minutes between each coat. You must allow it to cure before applying the next few coats.
The next few coats will be the same. You will need to maintain a constant flow to give it an even coat. Remember to keep the distance between 5"-6" and spray it on to where it looks wet but not thick and running. i would highly suggest you get a minimum of 4 coats but no more than 6 coats. You want to lay the plastidip on to where it is thick enough to peel off. Too few coats and its going to be a PITA to remove because you will not be able to peel it off in one strip. You'll be rubbing it off for days if its not thick enough.
After 4-5 good coats and allowing a 30 minute cure time between each coat, let the car bake in the sun for a good hour before you start removing the tape. Be careful when you start peeling it along the weather strip. To much of a pull will yank the entire plastidip off and not enough tug wont tear it. Use a razor or exacto knife if needed to make precision cuts along the strip.
I will post up pics of the final product up tomorrow when i take some.
Old Apr 3, 2012 | 12:41 AM
  #41
mw09g37's Avatar
mw09g37
wow this is ballsy to spray on the car... wait you can't just remove the pieces off the car? I could've sworn you could...
Old Apr 3, 2012 | 02:39 AM
  #42
G37X-Mars's Avatar
G37X-Mars
my friend just dip hes dodge ram truck...come out not bad.but i like vinyl more.
Old Apr 3, 2012 | 08:42 PM
  #43
qpham45's Avatar
qpham45
Ok so here is what the final results should look like. Its kind of dirty because it started sprinkling the day after. But if you look closely its very smooth and not grainy.
Window trim.
I dipped my diffuser as well. It was gloss black before.
From a distance
Old Apr 3, 2012 | 08:50 PM
  #44
surfjax87's Avatar
surfjax87
Get that chrome on the trunk dipped.
Old Apr 3, 2012 | 09:10 PM
  #45
qpham45's Avatar
qpham45
I'm dipping my entire car gunmetal. So the chrome trunk piece will be the same color as the car.
