2 Issues that drive me crazy ('09 37xs)
Old Dec 22, 2011 | 07:15 PM
mxquattro's Avatar
mxquattro
Overall I love my car but there are a couple of very minor things that drive me crazy.
- I have keyless entry and go, and the battery in the key goes dead every 2-3 weeks. Is that normal? It might very well be my own fault, because there have been times I sit down in the car and the panic button gets pushed by something in my pocket. Or I get to the car and it warns me my trunk is open (and it really is!) which leads me to think I actually am pushing the buttons on occasion. Since I dont actually ever use any of the buttons, is there some kind of small case I can put this in then put it in my pocket so I dont keep doing this?
-Secondly... Once in a while I start the car with the button, and it wont come out of park. I have to hit the brakes a few times and then it comes out of park ok (so far!). Is there any kind of adjustment? Its maybe 1 out of every 10 times. Im just afraid one of these days I wont get it out of park.
I also have an issue with wheel bearings I think. It hums on the hiway and drives me nuts. New tires didnt make any difference at all.
bob
Old Dec 22, 2011 | 08:05 PM
xtremeroller's Avatar
xtremeroller
1. Sounds like one of the buttons on your key may be sticking. 2. I had that same issue a few weeks ago with the car not wanting to come out of park. I was parked on an incline at the time. Since I stopped parking there I have not had an issue.
Old Dec 22, 2011 | 08:57 PM
surfjax87's Avatar
surfjax87
1. Battery life should be about 2 years or so on the remote, so either buttons are stuck or something.
2. Mine does that every once in a while. Never found a fix.
Old Dec 22, 2011 | 09:35 PM
JSolo's Avatar
JSolo
Just say no!!!!!
A hint for those with new(er) cars/remotes. Separate the halves of the remote you're not using, then store the pieces someplace safe. This breaks the electrical connection and ensures there's no parasitic draw.
Old Dec 24, 2011 | 01:54 PM
INFINITI G37's Avatar
INFINITI G37
Hello my friend..
I have something for u u might like and can b helpful..
This is a leather case for ur remote..
This is the link for purchasing..
Genuine Leather Key Holder | Key Fob | Infiniti G35 G37 Nissan 370Z GT-R
Best regards
Old Dec 24, 2011 | 02:05 PM
Tazicon's Avatar
Tazicon
I keep mine FOB in my front pocket with nothing else and have never had a problem. As far as the car coming out of park, the best thing I found is I get in the car, start it, then put my seat belt on, then go into gear. This seems to eliminate the not coming out of park issue. I think if you hop in and try to put it into gear too fast it seems to mess with it. Try it out and see how it goes.
Old Dec 24, 2011 | 02:36 PM
mxquattro's Avatar
mxquattro
Infinity G37 thanks for the link. It says I can still operate the buttons without taking the key out so Im not sure that will help me any. I need something that CANT operate the buttons.
Tazicon, Im definitely going to try that, thank you!!
Old Dec 24, 2011 | 02:43 PM
JSolo's Avatar
JSolo
Just say no!!!!!
I order some fob condoms. They are of silicon material which cover all the buttons. I didn't like the other ones that left the buttons exposed.
Old Dec 25, 2011 | 02:26 AM
INFINITI G37
yes my friend I know that the buttons still can be pressed because its just a case, but at least will be harder to push
Old Dec 25, 2011 | 08:17 AM
Hapa DC5's Avatar
Hapa DC5
The transmitter in the key may be going bad. Try using your other key for a while see how long that battery lasts.
Old Dec 25, 2011 | 09:24 AM
If your car is parked on an incline be sure to use your parking brake first before putting the car in park. This will keep the load off the transmission which can make it hard to move the shifter, it's also better for the car
Old Dec 25, 2011 | 08:27 PM
sammy917's Avatar
sammy917
question about key fob, may help op. if you put the key fob into the designated slot on the dashboard, does is charge the battery? cause ive gotten the lowbat warning for the fob and when i plug the key fob in, the warning disappears.
Old Dec 25, 2011 | 08:42 PM
JSolo's Avatar
JSolo
Just say no!!!!!
The fobgina (as referenced in a different thread) is nothing more than an rfid reader of sorts. When the primary battery is weak or dead in the fob, insertion of the fob into the fobgina activates the secondary transponder. There is a coil of wire that uses induction to power this device. Due to the very low power levels involved, the fob has to be in very close proximity. The receptacle in the dash provides this mechanism. It doesn't charge anything, it's simply a backup means of getting the car started.
Take apart the fob and you'll see it right under the infiniti emblem.
Old Dec 25, 2011 | 09:15 PM
LexiG37's Avatar
LexiG37
I massaged the fobgina but it didn't respond the way I expected. Must not like my type
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
pal51961
Sep 7, 2015 02:20 PM
Ihtbealexxx
Aug 23, 2015 01:58 PM
Badgerman
Aug 19, 2015 02:26 PM
Digilog
Aug 17, 2015 03:54 PM
