I may have a weird problem with my G37.
Old Dec 14, 2011 | 06:12 PM
kaoticdemize's Avatar
kaoticdemize
Ive had this issue a few times with my G but all the time with my SUV's so not sure if it is a vehicle problem or not. Generally I just hold up the hose a little bit and it seems to work.
Old Dec 15, 2011 | 02:22 AM
eksigned's Avatar
eksigned
haww!!! ME TOO! NO FIX though
Old Dec 15, 2011 | 11:54 PM
financeman's Avatar
financeman
Also happens to me occasionally. Really irritating when it happens....and I always fill my car at the same place.
Old Dec 16, 2011 | 01:11 AM
Itchytoe's Avatar
Itchytoe
Try pulling the nozzle out a little. It will alter the flow around it so the pressure sensitive device may not trigger.
Old Dec 16, 2011 | 10:21 AM
Yosemite Dan's Avatar
Yosemite Dan
I've tried that but it only works for 10 seconds or so. I guess I'll have to mention it at the next oil change and see what they do.
Old Dec 16, 2011 | 10:32 AM
Kidcane's Avatar
Kidcane
Florida G Club
I have had this corrected twice at the dealership. Either take your car in or only pump the gas at about 1/2-3/4 speed.
Old Dec 16, 2011 | 11:07 AM
carz's Avatar
carz
its obnoxious as hell, happens to all of us
put the nozzle in upside down
Old Dec 16, 2011 | 11:41 AM
devil2k's Avatar
devil2k
Same here. Happened few times at different stations. Ended up with gasoline all over myself the one time.
Old Dec 16, 2011 | 12:01 PM
JSolo's Avatar
JSolo
Just say no!!!!!
So this issue is due to excessive pressure build up while fueling, causing the nozzle to shut off prematurely?
Old Dec 16, 2011 | 12:18 PM
Kidcane's Avatar
Kidcane
Florida G Club
If I recall correctly it was the gas tank sensor was in a position that the gas coming in was hitting it and splashing the nozzle which made it think it was full and shut off.
Old Dec 16, 2011 | 02:47 PM
Yosemite Dan
But if you do that, will it still shut off automatically when it's full or does that bypass the sensor and I end up with gas all over the place.
Old Dec 16, 2011 | 11:10 PM
Itchytoe's Avatar
Itchytoe
It should still shut off automatically. I've never tried it though.
Old Dec 17, 2011 | 10:52 AM
Coprolite's Avatar
Coprolite
I just had this happen to me last night after reading this thread! I monkeyed with the nozzle before it happened and inadvertently triggered it. I continued the fill and drove off, only to see a 3/4 full tank. I will have to find the drawings for the system. I am thinking that I somehow got gas in the vapor return part of the system and messed up the feedback loop.
Old Dec 18, 2011 | 05:05 AM
  #29
MistAminER112's Avatar
MistAminER112
Had this problem on both my 08 G and 05 FX35...repositioning the nozzle to the left or right sides helps as well as slowing the flow of gas to a out 1/2 speed or less, as others have mentioned, but I think the real problem is the more I 'overfilled/topped off' the tank after it shut off the pump, the worse it would get. Still not sure on a fix though?
Old Dec 18, 2011 | 04:18 PM
  #30
Comatose's Avatar
Comatose
^ +1
Similar issues, i also find myself sometimes having to squeeze the trigger slower, or angle the nozzle off by 10 deg or so
