G37 Engine Stalling on Start up
Old Nov 5, 2011 | 01:56 PM
hainguyen281's Avatar
hainguyen281
Hello,
In the last couple of days, when starting up my car, RPM would rev up and then down to zero and the engine stalled. Repeated the step 3 more times before it would stay on. Any advice of what could cause it? Take it to the dealer? But I am wary that they say they cannot replicate it.
Battery is new because it was replaced under the TSB.
Old Nov 5, 2011 | 02:12 PM
tejasg37x's Avatar
tejasg37x
My 350Z did that after disconnecting my battery during a stereo installation...after driving it for a week or two it stopped doing it, and returned to normal.
I should add that mine happened only when the motor was warm...on cold start up it did not happen.
Old Nov 5, 2011 | 11:38 PM
cy7878's Avatar
cy7878
May be worth while checking the throttle bodies under DIY. My dealer service advisor said that's a sign for dirty throttle bodies, stalling on start up....
Old Nov 6, 2011 | 10:02 AM
Hapa DC5's Avatar
Hapa DC5
Any MIL on? Crank position sensor?
Old Nov 6, 2011 | 10:18 PM
eksigned's Avatar
eksigned
Originally Posted by cy7878
May be worse while checking the throttle bodies under DIY. My dealer service advisor said that's a sign for dirty throttle bodies, stalling on start up....
that's exactly what i was thinking. clean your throttle bodies -- your symptoms suggest that maybe the flaps aren't opening and closing as they should. either they're dirty (but isn't your car fairly new, OP?) or they're getting stuck, in which case -- dealership issue.
Old Nov 6, 2011 | 11:37 PM
hainguyen281
Thank you for suggesting cleaning the throttle bodies. It seems like I am experiencing the same thing as the posters in the DIY.
My car is a 2009 with almost 40K miles. I guess it is time to clean the TB.
Will the dealer clean the TB under warranty?
Old Nov 6, 2011 | 11:49 PM
cy7878's Avatar
cy7878
not a warranty item. The dealer rolls it into the 15K mile service and quotes $120 if done separately.
Thedbarz
33
Feb 9, 2016 12:05 AM
BANNISTER
Dec 10, 2015 04:14 PM
cellwoot
Aug 13, 2015 04:27 PM
G37xhibeet
MODDING 411
Aug 13, 2015 10:51 AM
reigle9
Aug 6, 2015 02:45 PM
