Not sure what it is but...
Old Oct 1, 2011 | 09:49 PM
rks's Avatar
rks
lately the back end gets loose a lot quicker. Maybe it's the cooler, denser, air. Can't be the drop-ins, but could be the Hotchkis or the quickly diminishing rear tread. Even the Ark sounds deeper but the car certainly seems more eager. Adding mods slowly keeps the car fresh and still fun to drive as I approach one year.
Old Oct 1, 2011 | 09:57 PM
prescott3656's Avatar
prescott3656
cold road/tires can play a big part in that. better keep your traction control on
Old Oct 1, 2011 | 09:59 PM
Probably the stiffer rear sway and balder tires.
dkmura's Avatar
dkmura
20 Year Member
Cooler weather = better torque
BUT
Worn tires = more oversteer
Also, with cooler temps, you should check your overall tire pressures, as every 10 degree F drop means 1 PSI less air pressure in each tire.
Old Oct 1, 2011 | 10:08 PM
rks's Avatar
rks
BUT
My TPMS light has already been on but another couple months and I'll be on winter tires.
Old Oct 3, 2011 | 09:33 AM
PeterUbers's Avatar
PeterUbers
I always felt that fall/winter months added 10 to 15 hp/tq to the 'G .. it also helps that I now have 43k on the ODO, and the engine is very much broken in.
Old Oct 3, 2011 | 12:10 PM
Itchytoe's Avatar
Itchytoe
Like those before me have said, it's a combination of the colder weather, worn tires, and stiffer RSB.
Jestered
May 27, 2014 10:14 PM
YarbroG37
Feb 28, 2014 09:06 PM
NewGMan
G37 Convertible
16
Aug 6, 2010 10:55 PM
Pennsylvania-G
Buying & Leasing
28
Apr 11, 2008 10:13 AM
