Upgrading the HDD
Old Apr 1, 2011 | 01:42 PM
Legz's Avatar
Legz
Originally Posted by devil2k
google g37 seagate "extreme condition"
see first 2 results
seems to be platter
I'd post links here but I recalled that links to competitor forums aren't allowed
The HDD looks difficult to remove, but will be interesting to see if SSD will actually increase the system load time.
Old Apr 1, 2011 | 02:34 PM
roots4x's Avatar
roots4x
For some reason, I bet checking on Nissan Forums would be more fruitful here. I just don't see the typical Infiniti driver knowing how to hack into their AV/Nav system.
Old Apr 1, 2011 | 02:55 PM
Legz's Avatar
Legz
This shouldn't be too difficult if we're able to copy the oem HDD w/o any issues, hmm might be a good project during this wkend...
Old Apr 1, 2011 | 03:30 PM
roots4x's Avatar
roots4x
Well, the thing I'm afraid of is that the hard drive has some type of firmware that prevents it from being easily upgradeable (even if it is sold as a PC compatible drive). I know very little about QNX but trying to make a weekend project out of a hard drive upgrade could potentially turn out to be a big PITA. Of course, it could also be plug and play and a simple disc image is all you'd need to get it working.
Old Apr 1, 2011 | 04:29 PM
devil2k's Avatar
devil2k
It's worth trying if the harddrive wasn't buried so deep. I don't think Infiniti takes them out for map update, so I assume that they use disc to load new maps. Perhaps there's a way to enter service mode to load map and there's a chance that an exploit could exist to buffer overflow the loading process to inject custom code. It's easier said than done.
Old Apr 1, 2011 | 06:27 PM
HappyG's Avatar
HappyG
Originally Posted by photoalexd
I think I read somewhere that Infiniti is using QNX (Unix based OS). I'm pretty positive it's encrypted, otherwise people would hack it left and right
FYI: QNX got bought by RIM (Blackberry) not a long time ago and their new tablet is running QNX-based OS...
QNX is rock solid. I feel safe driving my G knowing it is running QNX.
Old Apr 1, 2011 | 07:01 PM
roots4x's Avatar
roots4x
Does the car run on QNX or just the entertainment system?
Old Apr 1, 2011 | 08:07 PM
Mudgen's Avatar
Mudgen
As a long time systems engineer, and also drawing an inference from the fact that you only get 800MB of the 4Gb non-nav hard drive for music, I think QNX is used in running the car, not just the entertainment system.
Old Apr 1, 2011 | 08:34 PM
roots4x's Avatar
roots4x
I'm wondering how you came to that conclusion. My assertion is that the car's ECU would be completely separate from its AV system.
Old Apr 2, 2011 | 12:19 AM
JohnEnglish's Avatar
JohnEnglish
Yeah, QNX powers the car's infotainment systems (basically everything that you interface with via the centre screen) but the ECU and TCU are stand alone units.
Old Apr 2, 2011 | 01:47 AM
muyrec's Avatar
muyrec
People have been messing around with the nissan gtr music box. adding larger HD, etc.
check it out here. CompactFlash Music Player / Music Box limitation - NAGTROC - The Nissan GT-R Owners Club is it possible to modify it but there just isn't enough interest in doing it.
Old Apr 2, 2011 | 02:11 AM
JohnEnglish
Would adding a larger harddrive actually do anything? I imagine the 512 file limit is hard coded into the software so putting in a larger HD won't allow you to load on additional files.
Old Apr 2, 2011 | 02:25 AM
Legz's Avatar
Legz
It would be the load time I'll be looking for, replacing it with a SSD. It looks rather difficult.
Old Apr 2, 2011 | 07:59 PM
  #29
Mudgen's Avatar
Mudgen
Just a conjecture. I'm guessing that it's used to process some of the CAN data, and to interface that into the info part of the infotainment system. My idea of "running the car" may be broader than yours. Certainly the ECU is firmware based and not done by QNX.
Old Apr 4, 2011 | 07:15 PM
  #30
recycle999's Avatar
recycle999
Darn, I guess nobody has successfully attempted it yet.
