Ok, really need your guys help
Old Mar 26, 2011 | 07:10 PM
PR_G37's Avatar
PR_G37
Here are my car's specs: 2009 G37S sedan. Here are the issues I've had:
-Battery kept failing within first year so it was replaced under warranty
-Back brakes were bad within first year so they were replaced under warranty
-New 2nd battery started failing and it was recently replaced with the M model battery and the vent valve issue was fixed
This brings me to now. Today, it took 4 attempts to start up my car. The engine would turn on and then shut off one second later. It finally stayed on the fourth try but the engine sounded weak as if my car had the engine of a Toyota Prius or hybrid in general. It did drive fine though. Ever since I got this new M battery and the vent valve was fixed, sometimes I would start my car and the engine would turn on fine but then slowly start fading like it was going to automatically shut off. But then somehow the car would push through and stay on. What is going here?? This does not feel like a battery issue anymore. I do feel some slight rumblings underneath my seat sometimes after I turn on my car. Like the car is struggling with something.
Old Mar 26, 2011 | 08:49 PM
tharbemiko's Avatar
tharbemiko
I haven't experienced this myself but I suggest reading this thread:
https://www.myg37.com/forums/d-i-y-i...le-bodies.html
I think somewhere in the thread a member had the same issue as you. After cleaning his throttle bodies, the issue went away. Again, I'm not sure if this will fix your problem but it can't hurt to clean up the gunk in your TB.
Old Mar 26, 2011 | 09:29 PM
dkmura's Avatar
dkmura
20 Year Member
It would be interesting to see what your voltage is before startup. Do you have a multi-meter to check? If the alternator is not charging the battery fully, this is what could be happening. Otherwise, I'd suspect the voltage regulator is faulty.
Old Mar 26, 2011 | 09:49 PM
15951's Avatar
15951
Try putting a load on the electrical system - turn on the lights, turn up the radio, turn on the heated seats, roll the windows up and down. If that causes more issues, then it sounds like your alternator isn't charging the battery.
Old Mar 27, 2011 | 05:55 PM
PR_G37's Avatar
PR_G37
Thanks all. Will be talking to the dealer tomorrow and will hopefully have an update soon. Just getting annoyed with all these issues.
Old Mar 28, 2011 | 03:19 PM
PR_G37's Avatar
PR_G37
Spoke to service dept at dealer. They said unless a warning or service light is on, there's not much they can do as far as running tests and finding what's wrong since the problem seems to be so sporadic. My next servicing is in 1,000 miles so they said they can check it out then. Does anyone have experience breaking out of a lease b/c of car troubles? Wonder if the dealership can help me swap a lease for a new, healthy Infiniti b/c this is getting annoying.
Old Mar 28, 2011 | 06:23 PM
Maxpilot's Avatar
Maxpilot
The only thing the dealer will do is help you remove money from your pocket. Go the lemon law route.
Old Mar 28, 2011 | 06:29 PM
tharbemiko's Avatar
tharbemiko
Yeah if they're refusing to fix such a serious issue then you should do what maxpilot suggested..
Old Mar 28, 2011 | 08:23 PM
JohnEnglish's Avatar
JohnEnglish
The VQ37VHR uses the VVEL system to control air input into the engine. The throttle bodies are just for back up in case the VVEL system fails. Cleaning the throttle bodies wouldn't make any difference.
http://www.nissan-global.com/EN/DOCU...0713VVEL-e.pdf
From that presentation:
VVEL controls intake amount through intake-valves of the combustion chamber, where conventional engines used throttle valves
Old Mar 28, 2011 | 08:32 PM
dkmura's Avatar
dkmura
20 Year Member
Don't just get annoyed, take some action yourself. I wouldn't just take it to the dealer and expect them to disgnose everything. If you have a multimeter, you can check battery voltage yourself. It's not rocket science.
Old Mar 28, 2011 | 08:56 PM
PR_G37's Avatar
PR_G37
I agree and totally want to be proactive. My brother was successfully able to lemon law his IS350 and mentioned checking my car's computer log and seeing if it logged in the instances where the car failed to start or remain on after just being started. I spoke to the dealer about the car's computer log and they said it would not contain such information. Either way, I am very motivated to take action. I could be wrong, but this does not sound like a battery issue.
Manny735
Aug 14, 2017 09:25 AM
redlinernyc
Feb 29, 2016 11:06 PM
kavcheung
Jan 22, 2016 02:40 PM
ay37
Sep 15, 2015 08:51 AM
Simran Mann
Sep 11, 2015 04:42 PM
