10 mpg?!?!!?!
Old Mar 2, 2011 | 07:40 PM
platinumg35x's Avatar
platinumg35x
10 mpg?!?!!?!
So my gas mileage on my 08 sedan has been horrible. It's showing up on my dash to be 9.8 mpg
I drive for very short intervals, maybe 5-6 minutes tops local on a daily basis, and i don't even go really hard on the gas. I know short intervals (especially local) give you bad gas mileage, but 9.8 is just ridiculous.....any input?
Old Mar 2, 2011 | 07:44 PM
ScottyBeGood's Avatar
ScottyBeGood
9.8 is horrible. What are you driving a QX56?
Old Mar 2, 2011 | 07:45 PM
A_Palaroan's Avatar
A_Palaroan
somebody has a heavy foot.....
Old Mar 2, 2011 | 07:46 PM
zoner's Avatar
zoner
I would get the car checked out. I get 14 under multiple short trips in cold weather.
Old Mar 2, 2011 | 07:48 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
i dont even get that bad in short driving
Old Mar 2, 2011 | 08:08 PM
ijahman's Avatar
ijahman
Something is truly wrong with your car...even when I get into my car I dont get that bad MPG....
Old Mar 2, 2011 | 08:20 PM
platinumg35x
i've been trying to drive really easy to try to improve it, but it's not helping.....on the highway however i get the advertised 24 (around 70ish on cruise)
Old Mar 2, 2011 | 08:41 PM
15951's Avatar
15951
You answered your own question. The car isn't getting warmed up, so it's running rich on very short trips. I'm guessing that's also city driving with some idling at stoplights. If you're only going a couple of miles and the car is only running for 5-6 minutes without ever getting a chance to cover any miles, of course the mpg is going to be low.
I would recommend driving the car for 20 minutes from time to time so the engine can get completely warm and any water in the oil can burn off. Short trips like you're describing over a long period of time are hard on the engine.
Also, how are you measuring the mpg? Is it measured, or are you just looking at the display? If the latter, then a lot of idling will absolutely kill that number.
08g37's Avatar
08g37
i live in nyc so i get around 10-12 if your driving mostly city miles its pretty normal
Old Mar 2, 2011 | 08:45 PM
gooddeal's Avatar
gooddeal
Yeb, that's normal for 5-6 minutes trips in less than 2 miles w/ 8-9 traffic lights.
Old Mar 2, 2011 | 08:53 PM
Doggy's Avatar
Doggy
That's way off the computer is off cause I was getting 10.5 in a 4x4 v8 hemi eith 33inch mud tires in the city
Old Mar 2, 2011 | 10:41 PM
MOONLIGHT37's Avatar
MOONLIGHT37
what types of gas are you using?
Old Mar 2, 2011 | 11:19 PM
mw09g37's Avatar
mw09g37
it might be that your car isn't reaching normal operating temperature... what type of oil are you using?
i mean even a lead foot will get better mpg than 10... i mean not an instant read, but over the tank.
Old Mar 3, 2011 | 03:28 PM
platinumg35x
only use 93 octane and use synthetic oil, i let the car warm up before i drive it. Will be going on a long road trip this weekend so I'll see what mileage I get on the highway. thanks for the responses
Old Mar 3, 2011 | 04:24 PM
Marc Collins's Avatar
Marc Collins
Step 1, stop letting the car warm up. Drive away gently after 20 seconds and keep driving gently until it is up to full operating temperature (if it gets there in your short trip).
Step 2, accept 10 mpg if you live in a cold climate and do the type of driving you do. Also, you should remember that your driving pattern is considered the worst possible in terms of "heavy duty" and requiring the maximum maintenance (oil changes, etc.) (maximum meaning the shortest interval between servicing).
