Gas Pedal
Old Jan 26, 2011 | 12:10 PM
hmc's Avatar
hmc
Gas Pedal
Hi all. Just got my new G37x (slate blue) at end of December. Love the car, however its my first infiniti and the pedal seems really tight. Whenever I drive my calf gets tired and sore. I workout regularly and am in good shape, so that's not the issue, and have been driving for over 20 years and have never had this problem. Anyone else have a similar experience? Any ideas. Thanks!!
Old Jan 26, 2011 | 12:17 PM
hollywhip's Avatar
hollywhip
Have a 2010 sedan have not noticed it yet been on several long trips have you considered using cruise control?
Old Jan 26, 2011 | 12:19 PM
hollywhip's Avatar
hollywhip
Sorry forgot Welcome to the Forum and enjoy your new G great choice...!
Old Jan 26, 2011 | 12:24 PM
BuzzLY37's Avatar
BuzzLY37
i've had this issue sort of when i first got my car (never been in a vehicle like this before)
I was too used to pressing the gas at the tip. do you usually press the gas pedal with your whole foot or just the tip of your foot/toes?
if you put your whole foot on the pedal, it lessens the complication.
Old Jan 26, 2011 | 12:36 PM
hmc's Avatar
hmc
Thanks for the responses. I do a lot of local driving, so cruise control is not an option. And I have started to use the whole foot more as it does lessen the issue, but just weird as I've never had this problem before.
Old Jan 26, 2011 | 01:26 PM
Altie's Avatar
Altie
I am experiencing the same problem but in an reverse effects. Coming from driving SUVs (Trailblazer & Expeditions) it took sometime to get use to the responsiveness of the pedal. I've had to limit myself from pressing the gas pedal too hard, since a slight change in pressure on the gas pedal could send my car flying down the road.
Old Jan 26, 2011 | 01:30 PM
BuzzLY37's Avatar
BuzzLY37
My problem with it was that the camry's gas pedal is suspended in the air vs the G is a pedal on the floor, so I'm more naturally used to pressing with my toes to get sufficient response. Just something to adjust to, im glad it's helping you out.
Old Jan 26, 2011 | 01:42 PM
Chico's Avatar
Chico
I'd say there's something wrong with the pedal. Have it checked out at the dealer.
Old Jan 26, 2011 | 02:11 PM
eksigned's Avatar
eksigned
hm...i can't say that i've experienced the same, but in all honesty...being my first manual car, the third pedal threw me off for a little bit; i can honestly say that my left leg was a bit tired the first few bits. as for the gas pedal, you'll learn to shove it all the way down soon enough. unfortunately, your gas mileage...well, you get the idea. HAVE FUN! ENJOY YOUR CAR!
Old Jan 26, 2011 | 03:36 PM
crazjayz's Avatar
crazjayz
Check your seating position. I find that with the gas pedal, the angle between the face and the floor is near vertical, causing a lot of strain on my calf muscle as well. This is exacerbated because I like to sit flat and low with my legs stretched out.
Old Jan 26, 2011 | 05:28 PM
gee wiz's Avatar
gee wiz
Haven't noticed any unusual tension on the pedal here. But then, I used to own a Porsche 914 many years ago that was like doing a leg press when working the clutch and gas pedal, so anything seems a breeze in comparison. Next time you take her in for service get in another G and see if it's the same. You very well could have an isolated issue?
linvbro
Aug 22, 2016 01:25 PM
MrRiv
Sep 29, 2015 04:59 PM
si_driver
ECU Tuning / Dyno Data
24
Sep 29, 2015 11:38 AM
r0cketm0nkey
Sep 27, 2015 01:34 PM
