Jack point for floor jack
Old Apr 30, 2010 | 06:17 PM
afaa's Avatar
afaa
I was trying to do my first oil change with the floor jack and 2 support stands. I couldn't find in the manual where it mentions the jack points are for floor jacks. I picked a rigid point to my best guess but not sure if it's the proper place. I don't see any obvious locations for it so if anyone has an idea please share or post a picture would be great.
Thanks
Old Apr 30, 2010 | 06:21 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
there are two notches on the front and two notches on the back on each side where the emergency jack can go...just jack from there and you'll be fine
Old Apr 30, 2010 | 08:58 PM
Herm4376's Avatar
Herm4376
I purchased a 2010G37xS and had the same issue. I have a floor jack with a removable pad/dish but it is too big to use on the pinch weld jack points without damaging the rocker. I purchased this which works perfect Floor Jack Saddle - Rocker Panel Pinch Weld Adapter New : eBay Motors (item 250588286969 end time May-28-10 1350 PDT)
Old Apr 30, 2010 | 09:04 PM
soundmike's Avatar
soundmike
Underneath the front, in-between the wheels and just behind the plastic underbody shield covering the oil pan is a dimple. You can jack from there. I have a pic of it here:
g Gallery | ArcanJack | 20090821-DSC_0009-7 (this is looking at the jack from the driver side, looking forward -- the dimple is right above the jack plate).
For the rears, you can jack with the rear differential.
Old Apr 30, 2010 | 09:38 PM
MaxdOut's Avatar
MaxdOut
here you go....
Old Apr 30, 2010 | 09:43 PM
hispeed-lowdrag
Originally Posted by MaxdOut
here you go....
THAT is a great resource!!
Old Apr 30, 2010 | 10:08 PM
whiddles's Avatar
whiddles
I heard of people cutting hockey pucks as well.
Old Apr 30, 2010 | 10:44 PM
MaxdOut's Avatar
MaxdOut
I would not trust a piece of plastic that was cut... or any plastic...
Grip Pinchweld Jack Adapter
Metal FTW
Old May 8, 2010 | 12:50 PM
antirice's Avatar
antirice
I think this is the front jacking point, correct me if I'm wrong
Old May 8, 2010 | 01:35 PM
MaxdOut's Avatar
MaxdOut
yeah that's it, there is a little bump there
Old May 8, 2010 | 02:40 PM
LightsOut's Avatar
LightsOut
good info here
Old May 8, 2010 | 06:31 PM
chopper's Avatar
chopper
Eastwood has the jack adapters also, but at a slightly higher price:
Floor Jack Adapter For Late Model Cars
Old May 13, 2010 | 07:41 PM
afaa's Avatar
afaa
Thanks to all the contributions. You guys are awesome.
Old May 14, 2010 | 03:52 PM
Ron's Avatar
Ron
Jack adapter
Guys,
If I had my BMW adapter cut, will it work on my G37?
Thanks,
Ron
Old May 14, 2010 | 04:08 PM
Originally Posted by Ron
Guys,
Thanks,
Ron
Looks like it would. Notch it about 3/8" or 1/2" down the center.
