best 0/60 times?
Old Mar 29, 2010 | 12:21 AM
ozzypriest's Avatar
ozzypriest
I get a lot of spin off the line - takes a second or two for the car to hook-up - 60's are at 2.42, so I need to figure a what to get better hookup - 18 w the 245s, I guess? It really seems like wheelspin is my culprit in not getting below 5.5 0-60....how to avoid?
Old Mar 29, 2010 | 09:06 AM
ged1067's Avatar
ged1067
I'm in Fla right now but going back up north at the end of April. My house there is about 2 miles from the Pocono Raceway and there is a driving/racing school nearby. I'm thinking of taking some lessons in my own G so that I get the feel of what it can do; after all I'm 82 and haven't ever had this kind of car before! What do you all think of this idea (no snide remarks, I get enough from my family)
GED
Old Mar 29, 2010 | 09:21 AM
movinon's Avatar
movinon
That sounds like a great idea. I envy you.
Old Mar 29, 2010 | 12:59 PM
Alex57r's Avatar
Alex57r
I think the 0-60 times on the X are comparable to the times that the magazines quote for the RWD S models due to traction advantages of the AWD. However, in the quarter mile, I believe that the RWD will run away from the X.
Old Mar 29, 2010 | 01:00 PM
LightsOut's Avatar
LightsOut
I did 0-60 in 4.8 sec.
vdc off 225 tires
haha jk
haven't done any test yet
Old Mar 29, 2010 | 07:51 PM
Adam West's Avatar
Adam West
Originally Posted by SM_Shadowman
I was just checking out a few of those on the web. I'm thinking of going to one of the test-and-tunes one night to do a few runs with the car. Anything I should know in advance? I've never done it before. Would I need a helmet or any safety gear? Which track in MD do you like the best -- I'm in MoCo so I think the 75-80 looks like the closest.
For just doing one or two 1/4 mile runs is it necessary to switch to a racing oil or something like that?
One day I'd like to take some lessons or a real loop track experience or something like that -- but with a car that isn't my daily driver. My thinking is a 1/4 mile straightaway has a comparatively pretty low risk of damaging something.
Definitely go to a test & tune when the weather gets decent (low humidity and cooler temperate), usually can get quite a few runs in if you're quick to get back in line. Not too much to know about drag racing, just make sure your car is in good running condition (e.g. safe) and not leaking any fluids. They will do a tech check on the car to make sure you aren't going to leak anything on the track, but it's your responsibility to make sure your brakes and tires are up to the task. Make sure you're fluids are all topped off and oil is full. I usually bring a spare quart in case it decides to use some.
With our cars a helmet will be required if you break 13.99, which is certainly possible with the G. See here for specs: Frequently Asked NHRA Tech Questions or call the track. Not sure what happens if you don't run with a helmet and the car breaks into the 13s, they might ask you to get one or leave.
I've only been to Mason Dixon and liked the track, but whatever is closer for you. 75-80 is used by Motorweek to test their cars, it's been around for a long time and was recently re-furbished.
Playing around with tire pressure is also key to getting a good 60' time off the line, which has an overall effect on your 1/4 mile times. With my Altima (FWD) I found that lowering the tire pressure down to around 20psi gave me the best combination of off-the-line traction and good top end power. If you go too low you will start sacrificing your trap speed on the top end.
The key is to play around a little bit with the combinations during a test & tune and have fun! BTW, try to run with less than 1/2 tank for weight savings ;-)
Old Mar 29, 2010 | 07:53 PM
Adam West's Avatar
Adam West
Your car a auto or stick? Have you tried lowering the tire pressure down in 5psi increments to see if it helps your traction. I did this with my 6spd Altima (245/45/18) and pulled off a 2.1 60', which wasn't too bad for street tires and my launching abilities.
Old Mar 29, 2010 | 11:59 PM
SM_Shadowman's Avatar
SM_Shadowman
Thanks for the tips, Adam West. Is that really your name, or a tribute to Batman/mayor of Quahog?
Old Mar 30, 2010 | 05:55 PM
Adam West's Avatar
Adam West
Maybe a little bit of both
Old Mar 30, 2010 | 08:34 PM
cdso's Avatar
cdso
Maybe we should get a little MD group out to the track!
Old Mar 31, 2010 | 01:51 PM
BLKG37X's Avatar
BLKG37X
Batman would've looked better driving the G instead of the Batmobile.
Just picture it.... Black/Black G with Limo tint sitting on yellow 19's
Mmmmmmmmmm.....
Old Mar 31, 2010 | 02:14 PM
IgS's Avatar
IgS
I used the app for the iPhone (Dynolicious) so take it for what its worth.
consistently got around 5.4 seconds (best of 5.34)
i have a G37x with G37 coupe 19's.
im sure if I put the stockies back on, i can get it to around 5 even...
Old Mar 31, 2010 | 07:29 PM
Adam West's Avatar
Adam West
Hahah my old Altima looked sorta like the Batmobile, everything was black and smoked, minus the yellow wheels of course ;-)
A 5.3 0-60 is damn good still, could be the extra rolling mass from the 19s. I'm still on the OE 17s for now.
Old Mar 31, 2010 | 10:47 PM
  #29
ozzypriest's Avatar
ozzypriest
Originally Posted by x95stacey
What city? I'm just curious as to your altitude too.
Can't powerbrake above 1800 rpm, I think - there's a fuel cutoff at that point. I'd sure like to get that tuned out of my card. Wish somebody would break the code and release comprehensive software like HP tuners for this car. And it's transmission. I can't believe the tuner shops haven't been able to tune the tranny, it's killing me.
Old Mar 31, 2010 | 10:51 PM
  #30
ozzypriest's Avatar
ozzypriest
I'm AT. I'm better at launching an MT - drove those for 20 years. Yeah, I'm getting like 2.44 60's with awful wheel spin. Launching these cars well is really difficult. I feel strongly that learning the proper launch technique could shave .3 to .4 secs of my time. And better, fatter tires. I need the sport 18's with the 245s and some good all-season performance tires like Goodyear GTs or pilot sports - something that will hook up.
Plus, on top of all this, the new base, v-6 mustang is putting out 5.1 0-60s and 13.7 1.4s. What the hell? I can't let some little high school girl in her 2011 V6 Mustang outrace me!! lol, I got to get my time down. Actually I fond that pretty funny. Infiniti's 40k luxo-sport coupe is gioing to get killed on a regular basis by 22-23k base Mustangs because Infiniti couldn't come up with some decent torque. 20 more ft lbs would have made a huge difference, I think.
