New 09 G37xS...
Old Jan 11, 2010 | 08:51 PM
Infiniti7's Avatar
Infiniti7
someone was telling me it is normal for the seat or wheel to move a little after turning the car on when it adjust to your memory settings. anyone heard of this?
Old Jan 12, 2010 | 08:31 AM
KLB's Avatar
KLB
Only if you had moved them before.
Do you have the car set to move the seat and steering wheel when you get out?
Old Jan 12, 2010 | 01:25 PM
Infiniti7's Avatar
Infiniti7
yes the wheel and seat move when i get out. could that be the reason?
Old Jan 12, 2010 | 01:57 PM
DownstairsDave's Avatar
DownstairsDave
Wow.
Old Jan 12, 2010 | 02:08 PM
Did you read my post on the 1st page (post #9), if not, give it a glance
Old Jan 12, 2010 | 05:01 PM
Infiniti7's Avatar
Infiniti7
ya man im just a little confused about what your trying to tell me. If i have the option on with the wheel and seat moving when i get out of the car will that mean when i get back into the car and turn it on sometimes it wont match up exactly to my settings? is that why people disengage the setting? thanks
Old Jan 12, 2010 | 10:21 PM
It should return to your memory settings, maybe if you have your fob programmed into memory that will help, but not sure.
I just de-activated the feature because I didn't like all the activity, I have no problem getting in & out w/ my memory settings, but I could see it being useful if you have your settings pretty tight to the wheel or are a larger person.
Old Jan 12, 2010 | 10:58 PM
Infiniti7's Avatar
Infiniti7
What do u mean Fob? how do u program it into your memory?
Old Jan 13, 2010 | 12:20 AM
The dealer did mine, but it was pretty simple, should be detailed in the owners manual.
Old Jan 13, 2010 | 10:02 AM
Infiniti7's Avatar
Infiniti7
by linking that fob up to the seat memorys what does that do? u think it will solve my problem
Old Jan 13, 2010 | 07:55 PM
KLB's Avatar
KLB
The FOB is your remote to unlock the doors and such. You can match each FOB to one of the seat presets. When you unlock the doors with that FOB on you it will put the seats into your memorized position.
Old Jan 13, 2010 | 08:26 PM
Infiniti7's Avatar
Infiniti7
well i don't want the key to put my seat to the memory because when i enter the car i like how the seat and wheel slide back and move up. if i unlocked the car and the seat positioned to that setting it would be hard for me to get into the car.
Old Jan 13, 2010 | 08:59 PM
hawkeye98's Avatar
hawkeye98
How about going to the dealership and trying out the new cars on the lot to see if there's really a problem w/ your memory seats (if you can't recreate "the problem") OR if it's user error (if the new cars observe the same behavior). That would be the sure-fire way to get closure on your question. Good luck. Just curious, have you read through the entire user manual yet?
Old Jan 13, 2010 | 11:15 PM
  #29
To the OP, rather than spending time w/ all these posts back & forth I think you'd be better off spending that time reading the owners' manual. Cars used to be pretty basic, but the newer luxury cars have so many features and options that you'll be missing out on everything this car has to offer if you just get behind the wheel and "wing-it". Did you know you can roll all the windows down at once (to release summer heat) by just hitting the unlock button on the fob and holding it in for a few seconds?? See, you learned something new already, and it IS in the manual
Good Luck w/ your situation, I'm fairly certain it is related to your "auto-retract" option.
Old Jan 14, 2010 | 09:56 AM
  #30
Infiniti7's Avatar
Infiniti7
Thanks man appreciate it. Do you just keep your seat in the same position at all times? do u turn the auto retract off?
