Car Seems Sluggish all of a Sudden
Old Nov 20, 2009 | 05:48 PM
Silver37's Avatar
Silver37
I seem to be having some sort of new issue with my car. It doesn't spin up like it should, and braking is all of a sudden very touchy. It seems like something is dragging, and that is making the 7 speed AT do a lot more downshifting at lower speeds, which aggravates being able to brake smoothly. I already had the AT software upgrade, and everything seemed fine until a couple of days ago when this happened. Is there a history of stuck calipers or emergency brakes on the 09s or what? Could crud have built up on the rotors to where I need to clean them off by braking from a high speed? The brakes tend to squeal when I back up. I only have 10K on the car, so I would think it wouldn't be the brakes. I don't drive the car hard at all. Any thoughts/help would be appreciated.
Old Nov 20, 2009 | 06:44 PM
Boomer-Bob's Avatar
Boomer-Bob
Got any check engine or waring lights on?
Old Nov 20, 2009 | 07:50 PM
Silver37's Avatar
Silver37
Nope, no lights or anything to indicate something is acting up.
Old Nov 20, 2009 | 08:10 PM
mindonmatter's Avatar
mindonmatter
Do you smell burning brakes? If it were your brakes dragging, you would smell it.
Old Nov 20, 2009 | 08:12 PM
Silver37's Avatar
Silver37
No, nothing that would be obvious at all. Didn't know if there was yet another common G37 issue that I was dealing with on top of the high-pitched frequency issue.
Old Nov 21, 2009 | 10:15 AM
EnviedG35's Avatar
EnviedG35
Depending on your location your gas stations may be getting there "winter blend" of gasoline which usually causes decreases in mpg and possibly less power.
Old Nov 22, 2009 | 11:34 PM
PeterUbers's Avatar
PeterUbers
is your parking brake depressed?
Old Nov 23, 2009 | 01:38 AM
Mike's Avatar
Mike
This showed up last year at a dyno day; all the stock Gs were falling into two ranges depending on the gas they had...
And, of course some idiots showed up with 87 in their tank
Old Nov 23, 2009 | 04:22 PM
Radius's Avatar
Radius
Turn the snow mode button off... ;-)
Old Nov 23, 2009 | 04:46 PM
4DOORFUN's Avatar
4DOORFUN
It's the winter blend fuel. I noticed the change over as well. The throttle response is not as crisp. That's the only real change I could feel.
Old Nov 23, 2009 | 08:08 PM
Silver37's Avatar
Silver37
It's pretty bad...not sure that just gas would make it drive this poorly.
Old Nov 23, 2009 | 09:23 PM
CHI-TOWN G37's Avatar
CHI-TOWN G37
I seriously doubt it has anything to do with the brakes. Are your tires up on pressure? Big underinflation can make your car feel dumpy. I agree that it's probably just the gas blend.
Old Nov 23, 2009 | 10:47 PM
Silver37's Avatar
Silver37
Everything is perfect...tires, fluids, etc., so I'm not sure what the issue is. It's down too much HP for it to simply be the seasonal change of gas mixtures.
Old Nov 23, 2009 | 11:53 PM
The G's Avatar
The G
Maybe it's a lemon?
Old Nov 24, 2009 | 10:35 AM
CHI-TOWN G37
Bring it in. Maybe clogged injector(s).
