Dealer lip spoiler install
Old Aug 30, 2009 | 10:54 PM
duffster's Avatar
duffster
If all your seeing is a slight gap(about the thickness of a credit card) around the very outter edges, like 2 to 3 inches, it's what I've got on mine and what I've seen on the factory installed ones. Like I mentioned before the mounting tape doesn't run all the way to the ends and the rubber/foam strip is there to prevent the edge of the spoiler from rubbing on the painted surface of the truck deck.
Now if the rubber/foam strip is protruding or sticking out of that gap something could be wrong. Also the ends should not be loose, as mine are very snug.
I would check your local dealers lot and look for one or some that came installed from the factory and compare, then if you see something wrong you can point it out to them.
Old Aug 31, 2009 | 08:19 AM
g37musings's Avatar
g37musings
That is it exactly duffster. I have not seen a factory one on the lot, but will go hunt one down to compare.
Thanks for the all the feedback guys!
Old Aug 31, 2009 | 06:08 PM
DJ Hellfire's Avatar
DJ Hellfire
Originally Posted by g37musings
Tried multiple pics today, they all suck. It is the outer edge looking towards the rear of the car. Will try a few more. The tape is not what you see, but the rubber strip between the spoiler and the trunklid.
It's normal. It should be very barely visible and tucked under. Shouldn't be sticking out.
Should look like this:
Old Aug 31, 2009 | 07:29 PM
Chapinb's Avatar
Chapinb
Mine looks like DJ Hellfire's
Kind of a bummer, but O well, least the chrome is covered up
Old Sep 1, 2009 | 06:19 AM
g37musings's Avatar
g37musings
Bingo!
That is the exact gap that mine has. I just wish it fit a little better on the outer edge.
But I do still like the look of the spoiler.
Old Sep 1, 2009 | 11:45 AM
MaxdOut's Avatar
MaxdOut
That just looks wrong, the adhesive is not sticking at the outer edge. I have the coupe (different I know) with a factory installed spoiler the double side tape they use is a different color (dark grey) expands a little more so the edges stick.
Old Sep 1, 2009 | 11:56 AM
Alex57r's Avatar
Alex57r
Yeh, anything that covers that chrome thing is a winner... LOL
I still think its weird that you gotta drill a bunch of holes to put this thing on. It looks greatm but couldn't they just use the same holes for the chrome thing to hold it?
Old Sep 1, 2009 | 02:23 PM
dark86's Avatar
dark86
mine looks exactly the same... its so annoying that sometime leaves will get stuck in that little gap
Old Sep 1, 2009 | 10:38 PM
Silver37's Avatar
Silver37
That IS wrong! Looks like the boogered up spoiler on my '97 Maxima that I backed into a shopping cart at Home Depot a year ago. They need to fix it!
Old Sep 1, 2009 | 10:45 PM
DJ Hellfire
If this is like this on multiple dealer installs from around the country, then I'd say it's not the installer at fault, but the way it's designed. Mine doesn't move at all and is not loose. This is also a very up close macro shot. It's almost like zooming in on a small nose hair in the back of your nose.
Old Sep 2, 2009 | 11:40 AM
Alex57r's Avatar
Alex57r
Super Macro. I can see dust. LOL.
One can go crazy paying too much attention to little cracks on the back end of cars and things.
Looks good to me.
Old Sep 3, 2009 | 08:40 PM
G37beijing's Avatar
G37beijing
Other than the look of the new rear spoiler, are there any noticeable effects on driving dynamics?
Old Sep 3, 2009 | 10:07 PM
g37musings's Avatar
g37musings
None at all. Purely cosmetic.
xstarpro
Jan 19, 2016 07:15 PM
BANNISTER
Dec 10, 2015 04:14 PM
m3clubracer
Aug 26, 2015 07:36 AM
jessebritches
Aug 20, 2015 12:40 AM
cparise
Aug 19, 2015 01:51 PM
