CV axle g37x coupe
Old Jul 24, 2025 | 05:51 PM
BrandonG37's Avatar
BrandonG37
CV axle g37x coupe
Which cv axle fits the g37x coupe? does it need a tone ring ?
Old Jul 25, 2025 | 11:55 AM
ILM-NC G37S's Avatar
ILM-NC G37S
What corner do you need?
The tone ring is incorporated into the wheel hub itself.
Old Jul 25, 2025 | 04:30 PM
BrandonG37's Avatar
BrandonG37
I need front left for 2009 g37x coupe
Old Jul 25, 2025 | 06:56 PM
ILM-NC G37S
Here is what I found from OEM/ Dealership. There are also a ton of options over at rockauto.com. Then there are the chain stores...
What makes you believe you need to replace the halfshaft (axle)? Clicking or thumping?
Depending on where you are located there are usually local transmission shops that can rebuild your existing halfshaft.
Good luck!
Old Jul 25, 2025 | 07:38 PM
BrandonG37's Avatar
BrandonG37
Im in Ottawa and yes there is a clicking sound coming from the wheel well during a momentum shift a single click per change in momentum, If i choose rock auto which brand you would recommed ? and how much would a rebuild cost ?
Old Jul 26, 2025 | 10:26 AM
ILM-NC G37S
Being you are in Canada my advice will be next to moot... I would just contact your local auto parts chain store and see what they have to offer. As long as the replacement unit has some type of warranty attached you should be fine.
Last time I had front halfshafts rebuilt it cost roughly $75USD per- but this was for a older (1975) Oldsmobile Toronado and I honestly can't remember how long ago but at least a decade or so. With the prevalence of auto parts suppliers- both brick-and-mortar stores and online- rebuilding is becoming rare. It is just easier- and often cheaper- to just replace. I just tossed that idea out there as there may be a shop local to you.
Did you have a shop diagnose the issue or are you just "suspecting?" Might not be the halfshaft.
Old Jul 27, 2025 | 01:36 PM
BrandonG37's Avatar
BrandonG37
I had my bearings replaced recently, i was hearing a clicking sound over bumps and one when i go into re4verse or drive or brake hard. after replacing the bearing the sound going over bumps went away now its jsut that click sound a single clickk per change in momentum my mechanic said most likkely the half shaft.
Old Aug 18, 2025 | 01:22 PM
mummy2's Avatar
mummy2
https://www.vehicleservicepros.com/t...iti-axle-click
Said Amir
Dec 16, 2023 07:57 PM
TI4695
Mar 4, 2019 10:15 AM
blkceaser
Jan 5, 2019 03:06 PM
tscani
Jul 28, 2016 10:51 AM
Gthangftw
Apr 5, 2016 09:27 PM
