Most possible answer
Old May 11, 2025 | 03:45 AM
Allaidrees1's Avatar
Allaidrees1
No start no crank , replaced starter . Battery . Ipdm . Same symptom . Wet carpet under passenger side . I fixed the sunroof leak it was pretty bad . I checked the wires near the bcm and ecm no sides of corrosion .
Going to replace the harness that connects to ipdm and ecm .
no communication with obd2 i used to have communication but not anymore for some reason
was lost communication to HVAC module
and lost communication to TCM
im sure something in CANBUS
would bcm cause this ?
Hopefully it’s the harness that’ll fix it . We should see I want your opinions
Goes to accessory and ON but doesn’t start
I also did have a key light on awhile back and when I had the codes . So I replaced the battery fob battery .
It doesn’t turn off from ignition.
chitty
May 6, 2025 09:04 PM
Yellow
May 8, 2024 03:57 PM
MattM2012G37
General Tech Questions
Feb 21, 2023 12:22 AM
2011-G
Jun 8, 2021 07:26 PM
Save Crohl
May 20, 2020 12:19 PM
