Coolant line leak g37 coupe
Old Oct 25, 2024 | 02:56 PM
Made_inperu's Avatar
Made_inperu
Looks like behind the engine closer to the battery’s side this tube snapped or a connection is missing? My coolant was spilling out one day after a drive. I found the location. I’m just not sure what I am missing.
Old Oct 25, 2024 | 03:09 PM
Search the forum on "heater hose connector". No, never mind, just read this thread:
https://www.myg37.com/forums/d-i-y-i...-write-up.html
Old Oct 28, 2024 | 01:48 PM
monty2003's Avatar
monty2003
Replaced mine this weekend. All good now but it was quite difficult to get the broken coupler out. It broke apart and pieces fell deeper into the hoses. Getting the hoses out was also quite challenging. Ended up putting thick cardboard on top of the engine and laying on the cardboard to get at it. Turned the engine on and it shot coolant out with broken up chunks of the coupler. Fun times. Still super happy it wasn't the water pump.
2009
165k miles
Old Nov 4, 2024 | 08:36 AM
Originally Posted by mygia
If the hose is in place but appears loose, it might just need tightening. Also check the gaskets for damage.
No, the heater hose connector has snapped. It's right there in the pic.
Also, you can't tighten a constant tension band clamp. That doesn't make sense.
Also also, the OP made his post last month then never came back to the forum, which is kind of strange.
tite_tite
71
Mar 30, 2026 01:17 PM
Migs87421
Jul 27, 2023 02:08 PM
jakec17
Aug 16, 2021 10:46 AM
Mysteak
Sep 9, 2019 12:33 PM
Racindaddy
Jan 3, 2017 09:10 PM
