Help identify this wire connector
That is where the tow hook would bolt into from the front of the car. Normal.
Circled item #1, the Y-shaped item, appears to be the front crash sensor. This should be bolted to either the fan assembly or the radiator core support, I don't immediately recall.
Circled item #2, this is the coolant overflow hose. Normal.
The yellow mystery connector I will need more info about in order to pinpoint. Where is it exactly located/ near and can you tell how many wires there are and what colors each are?
thanks for the help, found that the yellow harness is for fog lights, i’ll be needing a new assembly since the vehicle had front end damage. was just really confuse by the random wire connecting to a mounting bracket but now ik it’s what it’s for👍🏽
Cement
Aug 6, 2020 09:06 AM
jdmtz2
Sep 1, 2014 02:41 PM
loz
May 8, 2013 11:34 AM
