More Mass Air Flow Sensor questions
Old Oct 16, 2023 | 02:08 PM
muufer's Avatar
muufer
2013 G37S Manual.
Been running my G37 for about 40k miles now(4years), and I have replaced the Air Mass Sensors twice. Any thoughts on other things that might be causing this? Yes I have been using the Amazon Air Mass Sensors. Do I need to get the OEM one's or do you thing their might be other things going on. TIA
So much fun to drive
Old Oct 16, 2023 | 07:08 PM
beefychicken's Avatar
beefychicken
What prompted you to change the MAF's?
I only ask because i had a wiring gremlin that haunted me for years in that the car would randomly go into limp mode and call out the MAF on the passenger side. I would pull it, clean it, reinstall it and was good to go until the next time i had problems. i then began swapping in MAF sensors, both OEM and AutoZone, but it never fixed it, In the end, through some wiring troubleshooting, i found there was a wiring issue on the passenger side, so i cut the harness back and installed a pigtail with connector and havent has any problems since. Based on that, and montoring MAF parameters, i noticed that there was a small split in airflow when i had an OEM on one side and AZ on the other. Not enough to casue troubles though, just a few % points difference.
Clean coupe BTW!
Old Oct 18, 2023 | 10:11 AM
muufer's Avatar
muufer
In my case the car will not start. I unplug the sensor and car starts and runs at 3000 rpm for a few seconds and then shuts off. I've replaced sensor three time. Have not figured if its the left or right.
Old Oct 18, 2023 | 10:41 PM
beefychicken
Is there an associated CEL? If so, have you checked the codes? Miht help narrow down the issue.
Old Oct 19, 2023 | 02:00 PM
muufer's Avatar
muufer
Yes, code P0133
We have detected an issue related to the intake, air temperature sensor circuit high. This issue may have a critical impact on your vehicles health. If realtor could be pie check and replace if needed or defective sensor.
This is from a Tmobile sync Obd reader
Old Oct 20, 2023 | 12:50 PM
beefychicken
Hmm, P0133 doesnt have much detail in the FSM, but it is related to O2 sensor-1 (A/F Sensor) Bank-1 (passenger side sensor - located before or in front of the cats).
And this from the internet:
Code P0133 Infiniti O2 Sensor Circuit Slow Response Bank 1 Sensor 1 (autocodes.com)
P0133 - INFINITI - Air Fuel Ratio Circuit Slow Response Bank 1 Sensor 1 (dtcodes.com)
Not saying this is the issue since there are no other supporting codes, but maybe it might help a bit.
Old Oct 20, 2023 | 04:00 PM
mummy2's Avatar
mummy2
Originally Posted by muufer
2013 G37S Manual.
I just happened to watch a Scotty Kilmer video yesterday and he said to always use OEM sensors. Don't know if that's your problem or not though.
Old Jun 18, 2026 | 07:17 PM
VQ70crap's Avatar
VQ70crap
i’m having a very similar issue can you help me?
Clean coupe BTW!
i have a 2013 sedan and one day it randomly went limp and would struggle to accelerate at all with little to no throttle response and then threw a P010B (MAF) light on and will now sometimes just randomly go limp can you go deeper into your wiring issue and how you fixed it it would be very helpful 🙏
Old Yesterday | 12:09 PM
beefychicken
I had limp mode on and off for years with the same MAF code each time.
When it happend I would clean the sensor and it seemed to work, but then fail again. I also tried replacing MAF sensors but still didnt fix it.
I bought a specialized cable from Amazon that let me swap the wiring, so that number 1 sensor was connected to number 2 car wiring and 2 to 1.
Limp mode and the same code happened again on the same side which confirmed a wiring problem.
I chopped up the cable into a pigtail of sorts then cut off the cars MAF connector and spliced in with the pigtail.
it hasn't failed for years so there was so something wrong with the car's connector.
you could start by cleaning the MAF sensors or replacing them. There are videos on YouTube that show how to do thay.
lightlypurified
MODDING 411
Dec 5, 2025 08:13 PM
stef
Mar 8, 2022 08:21 PM
venzz
May 9, 2013 07:52 AM
cp24eva
Intake and Exhaust
Jan 4, 2011 12:45 PM
warnerj1
Intake and Exhaust
Dec 27, 2010 07:15 PM
